Fog install help
Discussion in 'Lighting' started by metrick1215, Oct 14, 2013.
  1. Oct 14, 2013 at 8:16 AM
    metrick1215
    metrick1215 [OP] Pirate Medic
    BFE NEGA NC/SC/GA state lines....
    Black 2008 4x4 4door
    Ok so am i missing something..Wife bought me some fog lights for our 1 year anniversary. I went to install them and the fogs seem loose and i am afraid they will fall out. is there an adjuster that im not seeing or is there something im not doing right.
    1. Popped insert out.
    2. put fog light in.
    3.placed the adjuster round plastic piece in the correct spot..
    Also wanting to order a fog switch from http://www.otrattw.com/
    1. Which one do i need? i saw a lot of options for the switch itself.. VVPZCZL-1ZL
    2. What color better matches 2nd gen dashes amber or the Red
  2. Oct 14, 2013 at 8:34 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    The factory fog lights attach in 3 spots. There is the adjuster at the bottom that snaps into a hole in the bumper, then there are 2 tabs, halfway up the lamp that need to snap into holes in the bumper. Sometimes, the adjuster piece at the bottom can take a good bit of pressure to snap in place.
    As far as the switches, the amber color matches pretty well but is a little lighter than the factory orange. Any single pole, single throw switch will work for fog lights.
  3. Oct 14, 2013 at 12:16 PM
    metrick1215
    When i Put it in i can clip to the side that the clip is attached on the bumper, and the Adjuster goes in fine but the side that doesnt have a clip on the bumper just the hole is the loose side
  4. Oct 15, 2013 at 12:08 PM
    metrick1215
    Ok so i got them in place.. now need to wait till dark for alignment.. wired everything up and have them working so when i turn the corner markers on they will come on with the switch on.. (ebay switch sucks and doesnt fit like the website says but i kinda figured that)
    So on to the switch part of the question
    http://www.otrattw.com/proddetail.php?prod=VVPZCZL-5ZR is the switch im looking at now.. you said any SPST would work for the fogs..
    is this one?... V1D1GNNB Amber Upper independent/lower dependent.
    Will this work, and what is the difference between independent and dependent, is that when the Lower is on when power to it and upper comes on with the switch on..or vice versa
  5. Oct 15, 2013 at 12:16 PM
    Pugga
    Massachusetts
    F-150 Mod
    That switch should work fine. The amber is a little lighter than the stock dash but red is darker. Independent means you can wire the LED independently of the switch position. Dependent means that LED will only be lit when the switch is in that position. Upper independent means you could wire the top LED to the dash lights so that part would come on when your lights are on, same as the rest of the dash. Then the bottom dependent LED would only light up when you turn the switch on and power is running through the switch.
  6. Oct 15, 2013 at 12:18 PM
    metrick1215
    awesome thank you for the help! im ordering the switch now
  7. Oct 15, 2013 at 12:23 PM
    Pugga
    Massachusetts
    F-150 Mod
    OTRATTW makes nice stuff. I have 2 of their switches and really like them. Just so you know, they won't just press in, you'll have to dremel the hole a bit to make them fit. The stock locations have slots to accept a specific switch for a given location. The OTRATTW switch is a box so you have to file down the slots. You don't have to mess with the face of the dash, just the returns if that makes sense. If you have a dremel, it's a 5 minute job.
  8. Oct 15, 2013 at 12:26 PM
    metrick1215
    Thanks, ya i saw someone else on here showing how to install the switch itself.. i have a dremel and a file to make it right
  9. Oct 15, 2013 at 12:29 PM
    Pugga
    Massachusetts
    F-150 Mod
    I'm going to take this opportunity to whore out pictures of my dash with the OTRATTW goodness :D
  10. Oct 21, 2013 at 1:18 PM
    metrick1215
    Switch installed.. Love it!
  11. Oct 30, 2013 at 8:57 AM
    HtownBB
    HtownBB Active Member
    Jim
    Houston
    08 PreRunner SR5
    6" Pro-Comp Lift XD Wheels 33" Nitto Trail Grapplers M/T
    I love these switches. However, when I look on OTRATTW site I see a lot of confusion. It is on me I am sure.
    What do the options mean?
    Upper Dependent Lower Independent?
  12. Nov 2, 2013 at 11:30 AM
    metrick1215
    Ya there are alot of options.. This is the exact one i got..
    VVPZCZL-5ZR-V1D1GNNB
    Which is the Upper Amber lower Amber Single Pole, Single throw.. Which is what your going to be needing... This switch has two LED power plugs, and A switch wire and a ground...
    You can contact them if you are unsure and let them know what your looking for.
    And as far as what upper and lower dependent/independent is look at Pugga Post..
