Fog Lamp Button
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bendernut, Feb 11, 2012.
  1. Feb 11, 2012 at 9:04 AM
    Bendernut
    Bendernut [OP] Active Member
    Bend, OR
    05 TRD 6MT
    Is the switch for fog lamps, rear differential, and the power supply supposed to light up with all the other dashboard panel lights? Mine, of course, don't.
  2. Feb 11, 2012 at 10:08 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    My fog light back light turns on when I turn my lights on. I don't have the other buttons. There is a small bulb inside the switch, yours might be blown.
  3. Feb 11, 2012 at 10:12 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    They do in my 2010, but not sure if that would be the same in an 05.
  4. Feb 11, 2012 at 10:31 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    the only one on my 05 is the inverter.......the fogs and locker do not
  5. Feb 11, 2012 at 2:54 PM
    myname150
    myname150 Well-Known Member
    Same for my 08.
    Fog Light switch is either pushed in or not, no illumination :(
  6. Feb 11, 2012 at 4:27 PM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    dumbest thing ever....the only way you can tell if your fogs are on is if it's pushed in...no light. the back light illuminates when the lights are on, as stated.
  7. Feb 11, 2012 at 4:29 PM
    Fed Taco
    Fed Taco Well-Known Member
    Cale
    2011 TRD Off Road
    Wheels & Tires, weathertech floor liners, Areo Turbine Exhaust
    The one in my '11 doesn't
  8. Feb 11, 2012 at 4:30 PM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    You have a separate light on your fog lights? Pics.
  9. Feb 11, 2012 at 4:36 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Yes, the white fog light insignia is illuminated whenever the lights are on. It doesn't matter if the button is pushed in or not, it lights with the parking/headlights.
  10. Feb 11, 2012 at 4:49 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    At work now, but can go out on my break and take a pic around 8:30 ish.
  11. Feb 11, 2012 at 5:02 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    On my 07 the only 2 that don't light up once the parking/head lights are on are the inverter and mirror adjustment...everything else lights up.
  12. Feb 11, 2012 at 6:29 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Shit, my apologizes. I forgot to take a pic of my buttons on my break, was to busy scraping the thick ass ice off the windshield, so I can leave at 11. In my 15th hour at work, so wasn't thinking about it. I'll take a pic tomorrow.
  13. Feb 11, 2012 at 6:36 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    Mine dont
  14. Feb 11, 2012 at 6:38 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    The fog light bulb is illuminated from the back when the dash lights are on .
  15. Feb 11, 2012 at 7:08 PM
    OffroadToy
    4X4 Offroad
    here's what mine look like with the parking or head lights on...the top row right (inverter) and bottom left (mirror adjustment) don't light up. the inverter only lights up when the switch is pressed in to operate... sorry for the crappy pictures.
  16. Feb 11, 2012 at 7:12 PM
    05Moose
    Jim
    ^ I was going to just post pics off the internet. There's pics of it lit up all over by people that have changed the color. Mine's still orange though.
  17. Feb 11, 2012 at 7:19 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Mine do!
  18. Feb 11, 2012 at 7:19 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Ya thats what mine look like, I thought my inverter switch lit up, but now that I think about it, I don't think it does either.
  19. Feb 11, 2012 at 7:23 PM
    VanCity4x
    VanCity4x The shit show
    DJ
    BC
    05 Prerunner SAS
    3link 1tons on 40's and sum stuff
    All Tacomas have lights in switch. Swapped mine on my 2005 to white LED's. Removed the old burnt orange bulbs before replacing them. They only come on when your lights are on. It would be nice to have the light come on only when the switch is on but haven't found a way yet.
  20. Feb 12, 2012 at 8:25 AM
    Bendernut
    Bend, OR
    05 TRD 6MT
    I took apart the fog lamp assemble and found there is a bulb in inside. However, I have to go through Toyota for the replacement. There are no local stores that carry such a beast. The complete assembly, bulb and switch is $70 dollars. No wonder a new truck is ~$40,000. Toyota couldn't tell me the price on the bulb so Ill have to bring it to the dealership.
