Fog Light add to 2023 Taco,
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tgregory6852, Dec 10, 2022.
  1. Dec 10, 2022 at 1:27 AM
    tgregory6852
    tgregory6852 [OP] Retired Aerospace Engineer
    Upstate New York
    2023 Tacoma Access Cab, SR
    Dealer under coating. OEM Tacoma bed mat, Weather tech mud flaps and Window Deflectors. Also added bed lights and switch.
    Question is should the add a tap be plugged into an always on circuit or to a keyed only one. Or is there already a fuse designated for the fog lights?
    Thanks!
    Reference 2023 Tacoma SR Access cab
  2. Dec 10, 2022 at 7:31 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    What brand kit are you installing?
  3. Dec 10, 2022 at 7:50 AM
    tgregory6852
    Upstate New York
  4. Dec 10, 2022 at 7:59 AM
    Rusty66
    Rhode Island
    Ok, terminal 30 of the relay should go directly to the battery with a fuse inline as close to the the battery as possible. The terminal 85 or 86 (control side of the relay should also be fused if not already protected by the car) and should only be connected to source thats hot on low beam only, that way they turn off with the truck and turn off with high beams. More questions? fire away I'd be glad to help.
    EDIT: Looking at the harness on the site, put connection 1 to battery B+ and connection 6 to a low beam feed. If your looking for a low beam feed let me know.
    Connection 6 is a very low draw circuit so you could technically use a fuse tap and use the parking lamp fuse to power up that switch or find the fog lamp fuse slot (owners manual!) and see if it's only hot w/ key on and low beams on.
  5. Dec 10, 2022 at 8:12 AM
    tgregory6852
    Upstate New York
    Is it identified as low beam feed on the fuse block inside the cab or in the engine bay?
  6. Dec 10, 2022 at 11:07 AM
    tgregory6852
    Upstate New York
    Ok I think it is fuse #3 in the engine bay.
  7. Dec 11, 2022 at 5:57 AM
    tgregory6852
    Upstate New York
    Doesn’t “Connection 6” just power the light in the switch?
  8. Dec 11, 2022 at 6:09 AM
    Rusty66
    Rhode Island
    PM'd you.
