Fog light anytime mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2015TTDC, Jun 16, 2018.
  1. Jun 16, 2018 at 9:00 AM
    2015TTDC
    2015TTDC [OP] Well-Known Member
    2015 silver TRD Sport Double cab
    so I’m new here, but haven’t seen this done like this. My friend did it this was a few years ago on his 2015 with no problems. I just did it today on my 2015. Took me 5 minutes with a piece of 18GA wire and a pair of pliers. Totally reversible too if you need warranty work done as well. First you need to pull out the fog light relay and bend the outer prong to connect the wire to it (see first 2 pics.)
    Then take the other end of the wire and just snuggly insert it into the same port as the green wire shown in the last pic. That’s it. Done!
    Dogota, Jofaaustin91 and Tacomeister like this.
  2. Jun 16, 2018 at 9:28 AM
    Tacomeister
    Tacomeister Active Member
    Casey
    Long Beach, CA
    2013 TRD OR DCSB Prerunner
    Is this the fog light anytime mod? You didn’t specify what this mod does...
  3. Jun 16, 2018 at 9:41 AM
    2015TTDC
    Yea good point, just made the edit
  4. Jun 20, 2018 at 11:09 AM
    DOC 22
    DOC 22 GG
    Brandon
    13' DCSB Tacoma
    So this is easy to do?
  5. Jun 20, 2018 at 11:48 AM
    2015TTDC
    It can’t get any easier than this, I was done FAST. Buddy of mine has had it this way for a few years and no issues. Totally reversible too
  6. Nov 21, 2019 at 5:54 PM
    Bar fishing taco
    Bar fishing taco New Member
    2014 Tacoma sr5
    Sumo springs 3" lift in the front, 1.5" add a leaf rear
    I did this mod on my 2014 exactly the same way, my fuse boxes even look the same, the problem I had was fog lights won't turn off except with the ignition, what did I do wrong?
