Fog Light Condensation
Discussion in 'Lighting' started by Hunter500ky, Apr 4, 2011.
  1. Apr 4, 2011 at 3:54 PM
    Hunter500ky
    Hunter500ky [OP] Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Ok so it took me like 30min to figure out how to get the fog lights out.
    Once I figured it out, it made me feel like a TARD!!
    Ok so now they are out and I have read multiple threads.
    Do I need to open them up? If so do I use the same method as the lights?
    Heat oven to 300 (I think it was 300), turn the oven off, put the fog lights in wait 10 minutes then pull out and separate? Then again to put it back together.
    Now if I do that, I should also go ahead and seal around the light with silicone correct?
    Or should I just let them dry out and then seal them with some silicone to be safe?
    Thanks!!!!
  2. Apr 4, 2011 at 4:03 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    285/70/17 Goodyear BFG KM2's, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    I just did mine, and it is a real PITA. I used a heat gun, IMO I probably would have melted the inner chrome lens before the shell was warm enough to separate in the Oven. Heat gun was easier, but the hard part is separating them. I used a painters 5-in-one knife to wedge between the plastic and lens to scrape away the silicone, and finally they came apart. Yes you will have to buy more weather sealant to put them back together and assure no water leaks inside or condensation forms..
  3. Apr 4, 2011 at 4:08 PM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    10-4 Thanks
    What did you use to seal them back up?
    Any problems yet?
