FOG LIGHT help ???
Discussion in 'Lighting' started by chris2011, Sep 23, 2011.
  1. Sep 23, 2011 at 11:36 AM
    chris2011
    chris2011 [OP] Active Member
    CHRIS
    Hudson,NC
    2019 TRD OFF ROAD 6 SPD!
    Ok guys i got a kit off ebay and got lights in and wiring ran. Everything is plug together i jus have left a white wire and a green wire with a lil red clip thingy on end of it????(lol). Where do these two wires go??? THANKS!!!
  2. Sep 23, 2011 at 11:46 AM
    chris2011
    CHRIS
    Hudson,NC
  3. Sep 23, 2011 at 3:40 PM
    chris2011
    CHRIS
    Hudson,NC
    Finally got them to working!!! After searching TW found info i needed!!
  4. Sep 23, 2011 at 3:47 PM
    09DC4X4
    09DC4X4 Night In The Ruts!
    Brian
    Southern Maryland
    09 Double Cab 4X4 V6 Auto
    Too much, thanks TW.
    TW is the shiznit. Full of information. Just use the search button and look here before you buy anything! I have learned my lessons. Truck looks great btw and good luck with your build.
  5. Sep 23, 2011 at 3:53 PM
    NCTaco
    NCTaco Well-Known Member
    Brandon
    NC
    05 SR5
    secondary airfilter removed, deblinged , bhlm , satoshi grill
    nice to see someone local for a change NC FTW lol . how much did u end up spending on the fogs i need some to
  6. Sep 24, 2011 at 7:20 AM
    cverneau
    cverneau Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    I've been looking at those on e-bay as well - The seller is DT Moto.
    From what I can tell, it seems there are two versions of lights sold on e-bay. One has the plastic lens cover as a cup that attaches over the rear black housing and the other has a flat lens cover that is somehow fused to the rear housing. I can't explain it better than that as I'm only looking at photo's online.
    Do yours look exactly like the photo in the listing you linked to?? Those seem to be the lens cover as a cup version. How do you like them?? Are they pretty solid??
  7. Sep 24, 2011 at 7:31 AM
    bendbolden
    bendbolden Come and take them.
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    If you can post up some pics of your install. I have been looking at these too but wondered about the quality. Last set of lights I bought for my old F150 on ebay were crap. Hoping thats not the case here.
  8. Sep 24, 2011 at 1:52 PM
    Rye
    Rye .
    Texas
    2010 regular cab 4x4
    TRU short shifter, LCE header, Koenig Countersteers
    I'm installing the same lights and need a little help. I have everything hooked up, but they don't light up. I checked my connections with a meter and found juice at the green wire, white wire, and fuse relay, but not at the white connector on the red wire. The indicator light on the switch doesn't light up either. The fuse is good and I can measure power there as well. Any suggestions on what to do?
  9. Sep 24, 2011 at 2:14 PM
    Rye
    Rye .
    Texas
    Does it matter which parking light wire I connect the green to?
    I went with green because the wiring diagram for my truck shows that as the hot one and the white/black as ground.
  10. Sep 24, 2011 at 2:18 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    white goes to a 12v source coming from the batt and ur green wire goes to a parking light lead..ull find that coming out of a plug under the dash.. u g2 unbolt that plastic cover under the steering wheel. i looked at the color wire actually going to the parking light then found the same color wire under the dash and use a meter to find which one got power once the parking lights came on.. splice ur green wire into that
  11. Sep 24, 2011 at 2:27 PM
    Rye
    Rye .
    Texas
    I hooked it to the green wire at the back of the driver's side parking light. It goes under the dash?
  12. Sep 24, 2011 at 5:10 PM
    chris2011
    CHRIS
    Hudson,NC
    Got them from ebay for $74 and so far they working good.
  13. Sep 24, 2011 at 5:33 PM
    Rye
    Rye .
    Texas
    Thanks dayNnight4, you had me convinced I was on the right track so I rechecked everything and finally focused in on the switch. The contacts were bent backwards and missing where they were supposed to go. Now it's fixed.
    The cover is easy to pry off, and the button just pulls straight out.
  14. Sep 24, 2011 at 6:15 PM
    Rye
    Rye .
    Texas
    The only thing I don't like about it is that the switch LED color is green. Here is my quick and dirty almost-amber mod.
    I pulled the switch button off and cleaned off the overspray black on the backside to make it brighter. Then I colored the appropriate places with a red sharpie. Now it's almost amber and not so green. It looks more amber in person than in the picture.
  15. Sep 25, 2011 at 1:04 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Glad you got them working.
    Yes it does matter. If you don't use the green one and the bulb burns out you wont have power. It's like the old X-mas lights one bad bulb and the whole string is out. I didn't use a switch on mine and just wired the switch leg of the relay to the running lights and use them as daytime running lights. My Auto OEM fog mod http://www.tacomaworld.com/forum/lighting/170129-auto-oem-fogs-2nd-gen-tacos-without-fogs.html
  16. Sep 25, 2011 at 3:58 PM
    dayNnite4
    Nick
    Southern NH
    '11 4x4 5-speed AC
    np man. u can splice it into the parking light wire by the actual light itself or find it under the dash. either way works
  17. Oct 8, 2011 at 12:06 PM
    kkfritz1
    kkfritz1 Member
    Kristian
    Hillsborough, NC.
    '10 Prerunner 4X2
    Nerf bars, Solid truck cap
    I got the exact same lights, where did you run the wires thru the firewall?
  18. Oct 8, 2011 at 2:04 PM
    Rye
    Rye .
    Texas
    driver's side grommet
