Fog light help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deadbolt, May 3, 2013.
  1. May 3, 2013 at 11:06 PM
    deadbolt
    deadbolt [OP] do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    Hey guys,
    I just noticed my fog lights werent turning on. I tried to switching the fuse with another one and still no luck. A few weeks ago I replaced my current HID kit a new one which burnt out one of my headlight LO beam fuse. I immediately went back to my old HID kit. I am not sure if this has any correlation to the fogs not working now. I hope this isnt a serious matter. Any help would be much appreciated. Thanks in advance guys.
  2. May 3, 2013 at 11:30 PM
    deadbolt
    Socal
    bump!
  3. May 4, 2013 at 4:48 AM
    tacoma4
    tacoma4 Well-Known Member
    Check fuses, then try swapping relays. Then check that you didn't blow out both bulbs, replace them. Does your switch in the cab light up like normal when you turn it on?
