Fog light help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jrz Taco, Aug 2, 2015.
  1. Aug 2, 2015 at 10:04 AM
    Jrz Taco
    Jrz Taco [OP] Well-Known Member
    NJ
    2017 Tacoma DCSB SR5
    so I have been searching through multiple threads to get an answer before asking. I have the small fuse/relay box next to the main fuse box under the hood. However, I only have a relay in the small box for the air pump heater. No relay for the fogs. I just added fogs toy truck is there anyway to make it work without buying a relay from the stealership or no? Thanks in advance!
  2. Aug 2, 2015 at 11:30 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    IIRC (someone correct me if I'm wrong). Your wiring harness "should" already be there. All you "should" need to do is hook up the new fogs into the harness (assuming you are talking about the factory fog lights) and just plug them in. If you bought a base model most of the wiring is already there. They just deleted the items that plugs into them.
  3. Aug 2, 2015 at 12:01 PM
    Jrz Taco
    NJ
    Yeah wiring was there I have that all hooked up. I've been searching posts though and people have a relay in the smaller fuZe box that I don't have. That's what I'm wondering as to why they don't work.
  4. Aug 2, 2015 at 12:02 PM
    RearViewMirror
    Craig Christ
    Hmm... not sure then. I just assumed they would work once you hooked them up as most everything is wired and fused / relayed already.
  5. Aug 2, 2015 at 2:17 PM
    Jrz Taco
    NJ
    Thanks for trying!
