Fog light help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jnphillips77, Jan 19, 2019.
  1. Jan 19, 2019 at 4:54 PM
    jnphillips77
    jnphillips77 [OP] Member
    Josh
    2018 Tacoma SR Access Cab
    I followed Natori’s fog light guide and it all worked with the exception of tapping into the cargo light harness to get switch illumination. When I connect it as he directed, the switch lights up when fogs are off and comes on and stays on when fogs are switched off. Any advice????
  2. Jan 19, 2019 at 4:58 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    No idea, I’ll tag him for you. Might be a good idea to just post in that thread.
    @Nitori
    Welcome to TW
  3. Jan 19, 2019 at 4:59 PM
    jnphillips77
    Josh
  4. Jan 19, 2019 at 5:03 PM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    You swapped the switch illumination vs the trigger wire.
  5. Jan 19, 2019 at 5:05 PM
    jnphillips77
    Josh
    What’s the trigger wire? How do I fix this? Thank you. When I reverse the wires it still doesn’t work I’ve tried it.
  6. Jan 19, 2019 at 5:47 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    I'm gonna reply in the other thread with a more detailed explanation but it's because you bought a switch that's wired differently.
    doublethebass likes this.
