Fog light help?
Discussion in 'Lighting' started by Timmythetaco, Mar 8, 2019.
  1. Mar 8, 2019 at 5:31 PM
    Timmythetaco
    Timmythetaco [OP] Member
    Troy
    2013 ink blue Tacoma trd sport
    6” lift, 35’s, raptor style grill, Ditch lights.
    so i have a 2013 trd sport and i have the OEM fog lights that are installed and have the stock harness but there’s no switch in my cab. Should i just require it or try and figure out where the original wire is? I just want my fog lights to work lol. Thanks in advance!!
  2. Mar 8, 2019 at 6:48 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The Sports all came with fogs, so you are wired for it. You likely just need the switch. What does the switch panel to the left of the steering wheel above the pocket drawer look like? Your fog switch goes in the upper left location on that panel.
  3. Mar 8, 2019 at 6:59 PM
    Timmythetaco
    Troy
    There’s nothing there. That’s what’s confusing me. I have the relay and everything but no switch. And i don’t know where the wire is for the switch.
  4. Mar 8, 2019 at 7:04 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    So you have a blank in the switch spot? Pop it out, there should be the wiring behind it. Then all you need is the OEM switch.
  5. Mar 8, 2019 at 7:05 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    To the left of the steering wheel there should be 2 rows of three black rectangles, as @crashnburn80 said it should be the top row on the left (closest to the driver door). The plug for the switch will be behind the little black rectangle, use a pick and pull it out from the bottom. Just get a switch, aftermarket or OEM and plug it in.
    crashnburn80 likes this.
  6. Mar 8, 2019 at 7:08 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Hey brother change the thread title to something that pertains to your problem. Help or please help urgent are reserved for people stuck or in accidents that need assistance. Thread tools——>edit thread title. If not can @Daria or @jberry813 can we get it changed if he doesn’t.
    jberry813 and crashnburn80 like this.
  7. Mar 8, 2019 at 7:10 PM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    Edited title.
  8. Mar 8, 2019 at 7:10 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Valid point.
    El Duderino[QUOTED] likes this.
  9. Mar 8, 2019 at 7:11 PM
    El Duderino
    Jeremy
    HI->PNW
    Thank you
  10. Mar 8, 2019 at 7:13 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Think he may need a relay as well.
  11. Mar 8, 2019 at 7:19 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    He has a Sport though. Assuming it is a real sport, they all came with fogs, meaning someone removed the switch. So he should still have the relay unless that was removed too. The other option is it is a fake Sport, and didn't come with fogs, in which case yes he would need the relay.
    FastEddy59[QUOTED] likes this.
  12. Mar 8, 2019 at 7:21 PM
    Timmythetaco
    Troy
    I popped everything out and there’s no plug behind the dash. It’s a real sport. I’ll just have to take the full dash apart!
  13. Mar 8, 2019 at 7:22 PM
    FastEddy59
    Eddie
    My '13 SR5 came with wiring but no relay. Canada though, could be different.
  14. Mar 8, 2019 at 7:24 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Right but the SR5 didn't come with fogs like the Sport did, or at least they were optional on the SR5.
    That is really bizarre.
  15. Mar 8, 2019 at 7:56 PM
    Timmythetaco
    Troy
    Haha now you know my pain lol. I’m going to rip it all apart tomorrow so we will see
  16. Mar 9, 2019 at 10:34 AM
    Pacheco04
    Pacheco04 New Member
    ERICK
    Edinburg, Tx
    13 Tacoma Prerunner Silver 4dr
    CAI, Bug shield, Vent visors.
    I was wondering the same thing. I have a prerunner, I ordered fog lights for it, while installing them I saw wiring. But I didnt see the switch. But the dogs i ordered had wiring and a switch that need trimming to go into the slot. Or is the wiring for drl?
