fog light housing for 2015 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by arb808, Oct 19, 2022.
  1. Oct 19, 2022 at 10:46 PM
    arb808
    arb808 [OP] Active Member
    honolulu
    2015 magnetic grey tacoma 4x4
    looking for a fog light housing for my 2015 tacoma.i keep getting moisture in the housing and can't figure out where its coming from. i drained out the water and resealed the housing with silicone but after a couple weeks moisture returns.i purchased a set from eBay motors for my model but it didn't fit proper. anyone know where i can get a oem replacement preferably glass housing like the stock without breaking my wallet? or how to fix the moisture problem?
  2. Oct 20, 2022 at 3:46 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    If you re-sealed the housing and are still getting water in, it's probably coming from where the bulb seals to the housing with an O-ring. Once you get water inside though, even if you remove it and dry things out, your reflector will almost always corrode and significantly reduce light output. That said, you're better off replacing the housing - or better yet, replacing the pair.
    As for options on replacements, if you're happy with the performance of your OEM fogs, you can usually find used ones in the Classified section. If you want to upgrade your performance, you can replace them with something from this thread. (Hint: Diode Dynamics SS3 Sports are the best bang for the buck.)
    The LED SAE J583 Fog Pod & Fog Light Review | Page 304 | Tacoma World
  3. Oct 20, 2022 at 8:47 PM
    arb808
    honolulu
    thanks for your help!
  4. Oct 21, 2022 at 6:38 AM
    Pearson
    Pearson Well-Known Member
    Elliott
    Lexington Texas
    Black 2012 2.7L Prerunner
    Still, looking? I have a set I bought here and never used.
