Fog light install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reallycoolguy, Oct 19, 2022.
  1. Oct 19, 2022 at 6:47 PM
    Reallycoolguy
    Reallycoolguy [OP] New Member
    2014 tacoma
    Mine didnt come with fog lights is it as simple as plugging into the harness or do i also need a switch is there something someone can link me to so i can read about it
  2. Oct 19, 2022 at 6:50 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If your truck is prewired you will the the lights, the relay, the fuse, and the switch.
    If it's not prewired you will have to come up with your own setup.
  3. Oct 19, 2022 at 6:51 PM
    Reallycoolguy
    2014 tacoma
    It was prewired. I was hoping it was as easy and plugging them in and turning my headlights on haha
  4. Oct 19, 2022 at 6:57 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    it basically is but you do need the other components, I've heard of some prewired trucks having the fuse and relay installed (you will have to look and see) but none come with the switch.
    On a 14 the Fog Light Relay is in the little auxiliary fuse box under the hood (labeled FR FOG Relay) and the fuse is in the large underhood fuse box (labeled FOG FR 15A).
  5. Oct 19, 2022 at 7:00 PM
    Reallycoolguy
    2014 tacoma
    Is there a good place to buy the switch from?
  6. Oct 19, 2022 at 7:03 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  7. Oct 19, 2022 at 7:06 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Used one from a pick n pull would be the cheapest option, an OEM one on ebay is $50-$90.
    TnShooter likes this.
  8. Oct 19, 2022 at 7:10 PM
    Reallycoolguy
    2014 tacoma
    thank you for the help!
  9. Oct 20, 2022 at 2:00 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    You can also get a factory style switch from
    Ch4x4
  10. Oct 20, 2022 at 4:34 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You could but then you would have to wire it in as it won't plug into the factory plug.
  11. Oct 20, 2022 at 12:19 PM
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
    That is true
  12. Oct 20, 2022 at 6:07 PM
    Skytek
    Skytek Well-Known Member
    I bought this switch
    https://www.ebay.com/itm/263084422901
    for the price, the quality looks fine and has a oem look to it. I wanted the shorter more square ish model for where I wanted it. Bought oem take off lights from u user here, harness, relay, and bezels from Toyota parts. Haven’t had time to install it yet.
    The stalk switch seemed like to much effort and cost for the same functionality
  13. Oct 20, 2022 at 6:13 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Stalk mounted fog light switch is on 3rd gen trucks, 2nd gens have a push button switch on the dash.
  14. Mar 4, 2023 at 10:53 AM
    PJohnson99
    PJohnson99 Member
    Preston
    2014 Black Tacoma 4WD
    Morimoto Headlights KCM Summit Rims Running Boards Mickey Thompson Baja Boss tires
    Does anyone have a link for the relay and a switch that would work for 2014 Tacoma 4WD V6?
    I have lights installed with harness that came with truck already installed. Just seen I need the rest to get the lights working.
