Fog light issue
Discussion in 'Lighting' started by Buckwheat893, Sep 12, 2017.
  1. Sep 12, 2017 at 5:39 PM
    Buckwheat893
    Buckwheat893 [OP] Well-Known Member
    Cody
    Tucson, AZ
    2011 AC
    So I'm having trouble with my fog lights. I did the 2x3 led pod conversion with plug and play harness a few months ago, and everything has been great so far. Recently, the illumination light in the fog switch went out, but there were no other issues. Today when I turned my lights on, I had no fog lights even with the button depressed (on). If I turn all the lights off, leave the button depressed, then switch the headlights on, the fog lights turn on for <1 second then go out. With headlights on, operating the switch for the fogs does nothing. So my question I guess is should I replace the switch assembly as a whole? All connections seem good and clean and all fuses are intact. Any help would be appreciated
  2. Sep 12, 2017 at 5:42 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Sep 12, 2017 at 7:00 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    So you used a new wiring harness? Or did you splice into your factory wiring somehow? If you didn't splice into the wiring, then the headlights should have no effect on your new fogs. You'll either have a bad switch or a loose connection somewhere. I'd start there before taking anything apart or ordering new parts. I'd say start at the switch connections.
    Buckwheat893[OP] likes this.
  4. Sep 12, 2017 at 7:04 PM
    Buckwheat893
    Cody
    Tucson, AZ
    2011 AC
    I didn't splice, I used a plug and play harness. I took the switch out and cleaned it just now but that didn't help, I will go through the wiring between the factory harness and the lights themselves and clean things up then see what happens
  5. Sep 12, 2017 at 7:08 PM
    GHOST SHIP
    GHOST
    Separate your connections on the back of the switch and touch your positive and neg wires together. If the lights work, you have a bad switch. If the same problem persists, then you have a bad connection elsewhere.
  6. Sep 12, 2017 at 7:09 PM
    Buckwheat893
    Cody
    Tucson, AZ
    2011 AC
    Hmm never thought of that! I will definitely give that a try, thank you
  7. Sep 12, 2017 at 7:26 PM
    GHOST SHIP
    GHOST
    Here to help.
  8. Sep 12, 2017 at 10:05 PM
    Buckwheat893
    Cody
    Tucson, AZ
    2011 AC
    Turns out I ride the short bus, fog lights don't work with brights on! :facepalm:
