Fog Light kit for 2012 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by philvonville, Sep 8, 2012.
  1. Sep 19, 2012 at 6:28 PM
    Rotorheader
    Rotorheader Active Member
    Don
    Eugene, OR
    2012 Prerunner 4-cyl
    I'm still pleased with my setup. The '08 Camry lights for $50.00, a 4-post relay for $5.00, and an Add-a-Circuit for $9.00 ( $64.00 total ) Wired a trigger from low beams through the relay, and my fogs are on whenever my low beams are on. I leave the stalk light switch ON all the time, and it is hot with the ignition key. Lights and GPS go OFF when I turn the ignition off.
  2. Sep 20, 2012 at 11:50 AM
    5150Bronco
    5150Bronco Well-Known Member
    Bay Area, Ca.
    2013 Tacoma 4x4 Access Cab-Special Order.
    Funny you say that when I have read mix reviews on the fit of these lights. Just saying.
  3. Sep 20, 2012 at 1:26 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    I've only read one instance of the Camry lamps not fitting. Mine fit without any modification. The rest of the kit goes in the trash.
  4. Oct 18, 2012 at 8:27 PM
    orion44
    orion44 Well-Known Member
    Las Vegas
    2012 Reg Cab 2.7L
    Bakflip G2 tonneau cover, Coverking Mesh all-black seat covers, Pop & Lock PL5300 Tailgate Lock, MB TKO 16x8.5" wheels with alternate center cap, Yokohama 580 235/60-16 tires, after-market fog lights, K&N drop-in air filter
    Could you show a picture of the switch and the lights? I'm about to order a kit on eBay for mine and want to see a "non-representational" image... :D
  5. Oct 22, 2012 at 7:02 AM
    philvonville
    philvonville [OP] Member
    Phil
    Columbus Ohio
    2012 Prerunner Dbl cab 4cyl
    Here is a picture of the switch in the dash of my 2012 Tacoma Prerunner
    4 cyl. 4 door.
  6. Oct 22, 2012 at 7:23 AM
    B737
    Kevin
    Jersey Shore
    stock
    nice work phil! the indicator led is helpful. whats the back lighting color of that switch?
  7. Oct 23, 2012 at 9:46 AM
    orion44
    Las Vegas
    2012 Reg Cab 2.7L
    Wow nice, that looks pretty much OEM, maybe better since it has the LED indicator. Thanks for the the picture!
  8. Oct 23, 2012 at 11:15 AM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    sub'd. correct me if I'm wrong, isn't it up side down?
  9. Oct 23, 2012 at 11:19 AM
    B737
    Kevin
    Jersey Shore
    stock
    good eye! yep :)
  10. Oct 23, 2012 at 11:19 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Up for debate depending what a person likes.
    But I say yes, it's up side down.
  11. Oct 23, 2012 at 11:35 AM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    I'm glad I'm not the only one who put it in upside down, no point in changing it though
  12. Nov 12, 2012 at 8:31 PM
    orion44
    Las Vegas
    2012 Reg Cab 2.7L
    picture attached
  13. Nov 28, 2012 at 8:05 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    If you dont mind me asking,
    I am concluding that your truck came pre-wired for fog lights.
    Where did you find the wiring at?
  14. Jan 15, 2013 at 4:10 PM
    albano
    albano Member
