Fog Light Kit for 2013 Tacoma......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 5150Bronco, Sep 18, 2012.
  1. Sep 18, 2012 at 11:22 PM
    5150Bronco
    5150Bronco [OP] Well-Known Member
    Bay Area, Ca.
    2013 Tacoma 4x4 Access Cab-Special Order.
    I just bought a new 2013 Tacoma 4cyl 4x4 and want to put Fog Lights in.
    I have looked and I am pretty sure there is no pre-wire.
    Is there a difference from 2013 compatibility or do I need a new kit?
    Thanks for all the help! :D
  2. Sep 18, 2012 at 11:48 PM
    us3rname
    us3rname Member
    El paso
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/204749-2012-fog-lights-solution.html
    Read thru these posts. Im almost certain that what worked for my 2012 will work for your 2013. I ordered the kit from the ebay link in this thread. Only modifications I had to do were to the second set of screw holes to the fog lights. I used all the wireing includeing the relay and added in an add a circut to the headlight low beam and a fuse(since the kit didn't come with one) the switch in the kit will work if you want to put the switch in one of the center console blanks. If not then ditch that swtich. I ordered one for a 2011 and the pig tails.
  3. Feb 13, 2013 at 7:39 PM
    Armcphail
    Armcphail Member
    Aaron
    Chatham,Ontario
    4 cyl sr5
    Was yours pre wired?
