Fog light kit for SR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WNYBill, Aug 18, 2023.
  1. Aug 18, 2023 at 6:34 AM
    WNYBill
    WNYBill [OP] Active Member
    Bill
    Tacoma SR
    Is there a fog/driving light kit for the SR? Where and how difficult to install?
    Bill
    moe2o4 likes this.
  2. Aug 18, 2023 at 6:37 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    musicisevil likes this.
  3. Aug 18, 2023 at 7:24 AM
    radclerk1
    radclerk1 Well-Known Member
    Vic
    2017 Access Cab 2.7L Manual 4x4
    None
  4. Aug 18, 2023 at 8:33 AM
    WNYBill
    Bill
    Tacoma SR
    Great info, thank you.
  5. Aug 19, 2023 at 11:53 AM
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    I put one in my 2018 SR, cost was $50 for the kit. I had to replace the switch later with a better one for $15, so total cost was $65 plus the add a fuse. I followed the instructions in the first post, except I did not run the wire through the cable opening (it will chaff and short). Instead, I drill a hole through the fire wall (making sure there was nothing on the other side), painted it so it would not rust and then put a gromet in the new hole. I then ran the wire through. Good luck, the whole job took me about 2 hours, but that included putting all the wires in a wire loom.
