FOG LIGHT LED POD REPLACEMENT
Discussion in 'Cali Raised LED' started by CaliRaisedLed, Jul 7, 2016.
What setup would you be most interested in
  1. Brackets Only
  2. Brackets With 18W Pods
  3. Brackets With 18W Amber Pods
  4. Brackets With 16W Pods
Results are only viewable after voting.
  1. Sep 4, 2016 at 11:11 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  2. Sep 4, 2016 at 11:26 AM
    CaliRaisedLed
    CaliRaisedLed [OP] Well-Known Member Vendor
    Jake
    Texas (DFW)
    Yes they do, but we have a combo deal if you order our pods and brackets together.
  3. Sep 16, 2016 at 10:09 PM
    juan01
    juan01 Well-Known Member
    Guam
    05 TRD Sport Doublecab 4x4
    Toytec 3" Ultimate Lift Kit Light Racing LCAs
    These look badass!
  4. Sep 26, 2016 at 9:48 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Thanks.
  5. Sep 26, 2016 at 9:53 AM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Hurry up and get these '16s done so I can throw more money at you Jake!
    CaliRaisedLed[OP] likes this.
  6. Sep 26, 2016 at 9:57 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    I promise you'll be the first ones to get them!:rofl:
  7. Sep 26, 2016 at 11:25 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Any pictures comparing light output between stock fogs and these LEDs?
  8. Sep 27, 2016 at 8:45 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    We do not have any comparisons, but i can tell you any any one who has them they are 10X brighter than your regular ones.
    Kolunatic likes this.
  9. Jan 23, 2017 at 9:35 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    So far so good. I did accidentally switch the power and ground wire and shorted the 15amp fog light fuse. Instructions were okay but instead of explaining the orientation by paragraph, just add a photo and the dummies like me won't screw it up.
    These LED's replaced an HID 3k plug-n-play kit, which provided a more flood pattern and seemed a little brighter. On the positive side, these are much cleaner with the OEM adapter vs ballast/wiring harness/bulb/fuse combo which was a royal pain to trouble shoot when one side died. Next up: replace the candle light hella's w/ a bar.
  10. Jan 23, 2017 at 10:20 PM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Looks good
  11. May 4, 2018 at 11:59 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    OP updated
  12. May 8, 2018 at 12:50 PM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Super clean!
  13. Jun 5, 2018 at 11:03 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Great LED Fog light replacement
  14. Jun 8, 2018 at 10:57 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Another customer Picture!
  15. Jun 20, 2018 at 10:52 AM
    #35
    CaliRaisedLed
    Jake
    Texas (DFW)
  16. Jun 28, 2018 at 3:39 PM
    #36
    CaliRaisedLed
    Jake
    Texas (DFW)
  17. Aug 13, 2018 at 11:00 AM
    #37
    CaliRaisedLed
    Jake
    Texas (DFW)
  18. Aug 19, 2018 at 4:06 PM
    #38
    JakeTaco11
    JakeTaco11 Member
    Jake
    2011 Gray Tacoma 4WD DCLB SR5
    what size is the opening and will other pods fit in there? rigid d series 3x3 for example...
  19. Aug 19, 2018 at 4:07 PM
    #39
    JakeTaco11
    JakeTaco11 Member
    Jake
    also, if i have an aftermarket bumper, but it has oem spec fog light holes, will this still work???
  20. Aug 19, 2018 at 6:01 PM
    #40
    CaliRaisedLed
    Jake
    Texas (DFW)
    The 05-11 Fog replacement is a 5" Circle. Rigid pods will not fit inside of it as they mount in a different location. The brackets are intended for stock bumpers so it probably would not fit an aftermarket bumper.
