Fog Light Mod 2013
Discussion in '2nd Gen. Tacomas (2005-2015)' started by m.reed.1, Oct 10, 2012.
  1. Oct 17, 2012 at 11:21 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Haha after a few beers its all open game at that point but just in case you were serious you can't solder in a fuse backwards :p
    Stryker420 likes this.
  2. Oct 17, 2012 at 1:40 PM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    Just did the mod on my 2012. Simple and painless.
  3. Oct 17, 2012 at 8:48 PM
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    that's what the :D was for ;) hahaha :cool:
  4. Oct 21, 2012 at 3:58 PM
    FaSTBoY
    FaSTBoY Member
    2012 DBL Cab Sport
    I used a weathertight inline fuse holder and solder the ends on with some heat shrink to finish it up.
  5. Oct 21, 2012 at 9:30 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I am on week 1 of this mod I think? I don't know but I have been thoroughly enjoying this mod! Big props to 2006KJ for simplifying this mod so I didn't have to look into the wiring diagram to figure this one out on my own! :D
  6. Oct 21, 2012 at 9:57 PM
    Glocker23
    Glocker23 Drive fast take chances
    CT
    2012 DCSB Sport
    Debadged, Tonneau cover, Grillcraft MX grill, OKLED 20" light bar in grill, Aero AT2525 muffler
    Sweet. I pmed him too about a harness. Glad it's working out
  7. Oct 21, 2012 at 10:09 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I made my own harness using random materials I found within my garage. It surprises me that you guys can't make your own harness!
  8. Oct 21, 2012 at 10:12 PM
    Glocker23
    CT
    2012 DCSB Sport
    Yea well. I am not too confident at electrical stuff. Like what size fuse or size wire to use.
  9. Oct 21, 2012 at 10:20 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ahh, I see what you mean, it's all pretty general purpose, and as long as you have a basic understanding to electricity you will know what to do. BTW, If you would like to have one of those harnesses made for you, I can make one for you as well too. :)
    TACO3TRD likes this.
  10. Oct 21, 2012 at 10:34 PM
    SED
    SED Member
    Shawn
    Tacoma, Washington
    2014 TRD Sport double cab
    Fog light anytime mod. mounted holster in center console.
    I did it on my 2012. Easy as hell and the only problem I ran into was that the male connector was too big to slide into the female seat heater plug (no pun intended). But i just used some tin snips and cut a sliver off the width and was good to go. Works perfect.
    Also used the weather proof 10 amp in line fuse...
  11. Oct 21, 2012 at 10:53 PM
    2006KJ
    Front Royal VA
    thanks! :) but i cant take credit for this... i copied someone else on this forum that figured it out at the same time i did.
    ive sent most of these jumper wires out as a 'do some one else a favor" for free mod.. but i've since run out of materials... so $5 a piece has been the going rate. Glad to help out the tacoma community... seems to be great people!
  12. Oct 21, 2012 at 10:54 PM
    2006KJ
    Front Royal VA
    males connector was too big on every one i've done so far... i just trim them down with some wire cutters
  13. Oct 21, 2012 at 11:24 PM
    Glocker23
    CT
    2012 DCSB Sport
    If I was on that list sweet. If not throw me a pm and I will PayPal you to cover costs.
  14. Oct 22, 2012 at 7:41 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That was the biggest issue I ran into, and me not having the simple things which matter I wasn't able to cut it off or grind off enough material so what ended up happening with the connector was I snipped a sliver off of both sides and it kind of ended up looking like an arrow instead of a U style, it was sharp as a knife so I just dulled both sides on the ground a little so it wouldn't cut me or anyone else at any point :p
    The people here have been absolutely wonderful thus far, very helpful, much better then previous forums I came out of. A lot of jerk offs on those and it doesn't make me miss them one bit, I'll just carry on all my knowledge of vehicles here and give to this community more then I was willing to in the other!
    The only you will have to do is trim the male pin to size, you will see what we are referring to when you are installing it.
  15. Oct 22, 2012 at 5:32 PM
    #35
    Sargechris
    Sargechris Well-Known Member
    Oceanside, CA
    13 DCLB 4x4 TRD Sport/Tow Pyrite Mica
    BFG AT KO 265/70R17 Tires, SnugTop Sport Hi Liner, Yakima Racks / Load Warrior, WeatherTech Floor Liners, BedRug/BedMat
    Got my splice--Thanks! :thumbsup:
    But my Seat Heater plug has no contacts.... :(
    I guess I'll have to try the other method?
    Will advise in the future....
  16. Oct 22, 2012 at 5:36 PM
    #36
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    does anyone read anything?
  17. Oct 22, 2012 at 9:11 PM
    #37
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is also one right above the relay if I recall correctly which should have terminals. I don't remember which pin was the hot one on key on though.
  18. Oct 23, 2012 at 7:58 AM
    #38
    Sargechris
    Oceanside, CA
    Yeah, I read it... but I was too darn lazy to look until the splice arrived! ;)
    If anyone has more info, I'm interested.... :cheers:
  19. Oct 23, 2012 at 8:11 AM
    #39
    Glocker23
    CT
    2012 DCSB Sport
    All done. Thanks guys. It looks so much better. Next idea is to by pass dtrl when sitting in park. Lol
  20. Oct 23, 2012 at 8:18 AM
    #40
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I can find out later but you gotta ask nicely. Lol.
