Fog light mod for 2014 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Captain Magpie, Mar 13, 2014.
  1. Mar 13, 2014 at 4:01 PM
    Captain Magpie
    Captain Magpie [OP] Well-Known Member
    Southwest
    SR Debadged
    Debadged
    Hey guys
    Been going through the fog light mod threads and have not seen anything for 2014 trucks. In looking at various methods and my relay clusters it appears that my truck is wired differently, can anyone shed light on this mod for 2014 trucks?
    Thanks in advance!
    Cheers
  2. Mar 13, 2014 at 4:07 PM
    JTTRDSPORT
    JTTRDSPORT Active Member
    Jim
    New York
    14 Tacoma TRD Sport
    Working on it.
  3. Mar 13, 2014 at 4:55 PM
    cholland
    cholland Active Member
    California
    13 Access cab 4x V6 manual
    I haven't seen anything to indicate the '14s are different from the 12 & 13 models.
    What your seeing are mods written before the 14s were out so no reference to them.
    Changes occurred with the 2012, grill, interior, etc. so anything for 12 or 13 should apply to 2014 too.
    Expect some updates and changes for 2015 models.
  4. Mar 13, 2014 at 5:00 PM
    Reel Tuff
    Reel Tuff Well-Known Member
    Gary
    western Pa.
    2014 tacoma sport DC
    Wet okoles,weather tech digital mats,Tacoma bed mat and stage II light kit, LP & 3rd brake
  5. Mar 13, 2014 at 7:34 PM
    tacotacoburrito
    tacotacoburrito Well-Known Member
  6. Mar 14, 2014 at 11:30 PM
    Captain Magpie
    Southwest
    SR Debadged
    Debadged
    Jim thanks for the reply! So I believe I have the same setup based off of your link but I have a ?
    1. Where does the brown (male pin) plug into
    2. The link shows the factory relay being used?
    I think I have it figured out but I don't want to melt my elec sys lol....
    Cheers
    Brett
    P.s. What "other" relay did you use?
  7. Mar 15, 2014 at 6:21 AM
    JTTRDSPORT
    Jim
    New York
    14 Tacoma TRD Sport
    Working on it.
    You remove the grey relay in the picture and slip the brown wire into the slot at the bottom of the relay. Once you pull the gray relay out you will see where it goes. I also put a fuse in the grey wire just to be safe.
    I bought an aftermarket relay at autozone just incase I had a problem. The relay number is 90080-87026, It is an exact replacement.
    Part Number: 20382
    Alternate Part Number: 41-5465
    Warranty: Limited Lifetime
    Xref Brand: Toyota
    Xref Part #: 9008087026
    OEM TechNote: Multipurpose relay.
    CHECK THE FIT
    I tried the bent pin mod and used the above relay and I must have screwed up the relay because it did not work. I was happy I was using the aftermarket relay.
  8. Mar 15, 2014 at 6:37 AM
    kevinsc
    kevinsc 2012 dbl cab 4x4
    kevin
    columbia, south carolina
    12 4x4 dbl cab
    chrome on front painted to match, satoshi grill done by myself, BHLM, billys all the way around with ome springs upfront and LR ucas with wheelers 3 leaf progressive pack in the rear, mb gunner wheels powdercoated black on 285/75r16 nitto trail grapplers, tinted all the way around and on windshield, pioneer dbl din touch screen with two 10's behing the seat and new speakers all the way around and certain interior parts painted to match, also have a road wire leather kit black with red stitching sitting here waiting for me to find time to install it!
    I did thismod in my 12 and the way i did it you cant see any wires and it has worked perfect now for 2 years and i will take a detailed pic this weekend and try and get it up this weekend or moday
  9. Mar 15, 2014 at 1:17 PM
    Captain Magpie
    Southwest
    SR Debadged
    Debadged
    Jim thanks for the info I have an autozone down the street. Well it turns out that I only have two light blue relays in the smaller box that is next to the main fuse bus. Does anyone have a photo of a 2014 SR model main bus with this mod or at least a photo of a 2014 with the fog and ign relay pointed out in the main bus? I'll post a picture of my layout tonight.
    Cheers
