Fog Light Mod--Pics Included
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Simon2150, Feb 26, 2010.
  1. Feb 26, 2010 at 5:37 AM
    Simon2150
    Simon2150 [OP] Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    I wanted to start this thread as a supplement to piercedtiger's post and Crom's thread on this mod:
    piercedtiger:
    http://www.tacomaworld.com/forum/technical-chat/4838-cheap-free-mods.html#post45430
    crom:
    http://www.tacomaworld.com/forum/li...glight-mod-explained-electrical-diagrams.html
    I started off by gathering the needed supplies:
    1. Spool of 18 gauge wire (from radioshack)
    2. Electrical tape and heat shrink tubing (not in pic)
    3. 1 Female Blade Connector-- http://www.radioshack.com/product/index.jsp?productId=2104016
    4. 1 Wire tap-in squeeze connector-- http://www.radioshack.com/product/index.jsp?productId=2104093
    5. 1 butane lighter
    6. 1 roll of electrical tape
    7. Plier of your choice (needle nose or regular)
    I opened the hood and popped the cover off the fuse box and then removed the appropriate relay
    I used the needle nose pliers to place under the relay then pried it upwards. I repeated this on the other side because my hands weren't strong enough just to pop this off, LOL :p.
    I then bent the prong on the right side (remember the orientation of how the relay plugs in) like this pointing to the inside of the vehicle.
    I then cut about 8" of wire from the spool in the 1st pic, stripped one end to expose wire, inserted the female blade connector, and crimped it down
    Next, I inserted the blade connector and attached it to the bent terminal on the relay and applied heat shrink tubing to help seal the connection (heat shrink tubing not required, but I wanted to do it. Alternatively, you can wrap it with electrical tape too.)
    This is where I used the butane lighter to shrink the tubing onto the connection. When you do this, do not leave the flame in one place for too long, I would keep it moving along the length of the tubing until it shrinks. I did a sloppy job, but know now how to do it better (my 1st time with heat shrink tubing). If you're unsure how to do it, either practice before actually doing it or just use electrical tape.
    I then went back to the truck and poked a hole through the plastic to run the wire through. Basically, where the green arrow is, stuck my knife there and in a circular motion cut out a hole just big enough for the wire to pass through
    Next, I unplugged the harness that had the green wire and "isolated" it so that I would have more room to work
    Then, I took the wire tap-in squeeze connector and placed the green wire inside it and then took the red wire and placed it on the other side
    I crimped down on the wire tap-in connector and then closed it
    Sorry for crappy pic, started to run out of daylight
    Lastly, I plugged the relay back in and then the wire harness that has the squeeze connector back in, cleaned up everything and tested it out and VOILA--
    Fogs now work when ignition is on! I hope this helps out other TW'ers who want to do this mod. Thanks to piercedtiger for the initial post and to Crom who answered some of my questions in his thread.
  2. Mar 13, 2010 at 5:33 AM
    Major91
    Major91 Well-Known Member
    Masshole
    2009 TRD OffROAD Barcelona Red
    On Anytime Fog Lights Satoshi Grillcraft Misc LEDS 5100's all around Konig's16". Duratracks, debadged,tinted fronts, custom shifter, flyzeye
    Simon great write up bro! I have this mod lined up for tomorrow afternoon and with your pics dude no one can go wrong! :thumbsup:
  3. Mar 13, 2010 at 6:20 AM
    Logically Insane
    Logically Insane Well-Known Member
    Wes
    TN --- USA
    2010 PreRunner Access Cab
    Kobalt toolbox mounted with J-Hooks, Locks on storage compartments in bed, Window Visors, Toolbox LED Lights, Underbody Lights, More to come.
    You just made me want to try this.. lol
  4. Mar 13, 2010 at 6:29 AM
    TACONORM
    TACONORM Member
    NORM
    FL
    2010 TRD OR 4X4
    Great write up with awesome pix. Looks pretty simple to do with your pix. Just not sure where the plug with the green wire is. Could you show that plug or tell us where to find it??? Thanks
  5. Mar 17, 2010 at 3:28 AM
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
    so this mod is just to have the fogs on like a day time running light?
  6. Mar 17, 2010 at 3:31 AM
    James3492
    James3492 Well-Known Member
    James
    EAST COUNTY
    Black-out Tail lights Painted Rims & Hood Scoop
    Amazing :) Thanks :) i might be using this for when i get my d2 Projectors :)
  7. Mar 17, 2010 at 7:25 AM
    WVtriple
    WVtriple Well-Known Member
    Anthony
    WV eastern panhandle
    07 DC TRD Sport
    Satoshi grill mod, Redline Tuning Hood struts and tailgate E-Z down, HID headlights and fogs, LED tail lamp upgrade, TRD exhaust, FJ TRD Anthracite Wheels, T-REX eyelids, power sunroof, 5100 Billies and ToyTec AAL, K&N drop-in, TRD seatcovers, Weathertech floor mats, Fog light any-time mod, Pop-n-lock, slotted front rotors with ceramic pads, BenWa power rear slider mod, blackout badges, and blacked out center stack and console. 7" HID's behind the grill. LED light bar in the lower grill. Trailer plug relocate. Auxiliary reverse LED's wired in to be manual or auto on when in reverse.
    Did this one last weekend, and just like your post, it was that damn easy!
    Nice write up.
  8. Mar 17, 2010 at 8:29 AM
    Major91
    Masshole
    Also did this last weekend - took all of 10 minutes. :D
  9. Mar 17, 2010 at 8:42 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    '10 TRD SPORT Acc.Cab Mag Grey 4x4 Auto
    Weathertech floor liners, stone and bug deflector, Putco Element In Channel Window Visors, Viper remote starter, Harley lighted hitch cover, Herculeze front mudflap, Metal Miller Harley Grill Emblem, SockMonkey design Bedside Decals and 3rd Brake light TRD decal, K&N Air Filter, Goodyear Duratrac 265/70/17 C load, Valor Exhaust tip, De-badged tailgate, Advantage Tonneau Cover, Tacoma bedmat, Bicycle Mount Rail mounts, Custom Ipod holder. Stock Suspension :( (winter wheels: 2014 16" stock steel wheels plastidipped black with general arctics 265/75/16)
    Its so you can have fog lights on anytime with or without Headlights on, and with high beams too.
  10. Mar 17, 2010 at 10:34 AM
    bdwsrjoe
    bdwsrjoe Well-Known Member
    Joe
    Rio Hondo, TX
    08 Tacoma Double Cab TRD Offroad 4X4
    K&N Cold Air Intake, Magnaflow Catback Exhaust, 3" ToyTec Lift Kit, JVC InDash DVD Player with Backup Camera, 2 10" JL Audio Subs, 8K HID Headlights, 8K HID Foglights, N-Fab Nerf Steps, In-Channel Ventvisors, springfield xd40v10, mossberg 500 12ga.
    This mod kicks ass! The only thing i noticed is if you leave the fogs on and the wifey borrows your truck at night she will drive away thinking the lights are on when they really arent. Your tail lights will only come on when you hit the brakes.
  11. Mar 17, 2010 at 1:22 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Daniel
    Utah
    08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Is this like the other versions were the fogs come on for about 90 seconds after a few hours of the truck being parked?
  12. Mar 17, 2010 at 3:17 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
  13. Mar 17, 2010 at 3:31 PM
    Simon2150
    Austin, TX
    If u pop ur fuse box in the hood u will see it. Look at piercedtigers pic of the finished product and it'll make sense.
  14. Mar 17, 2010 at 3:33 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    Forgot to use the flash feature on your camera?
  15. Mar 17, 2010 at 3:34 PM
    Simon2150
    Austin, TX
    No this method taps into ignition wire which does not come on after a few hours.
  16. Mar 17, 2010 at 8:29 PM
    347Coupe
    347Coupe Member
    Tim
    Yorktown, VA currently.
    +2! I did this today in the parking lot on base in under 5 minutes. Also helped a buddy with his.
    Thanks for the step-by-step pics!
    No complaints after mod so far.
    -347.
  17. Mar 17, 2010 at 8:34 PM
    Simon2150
    Austin, TX
    LOL, my iPhone doesn't have flash
  18. Mar 17, 2010 at 8:40 PM
    eskamo23
    eskamo23 Well-Known Member
    Pasadena, CA
    trd sport
    TRD cai with (AFE dry flow filter), de-flapped, tint, weathertech floor liners,coverking neoprene seat covers, rear TSB, Billy 5100's set at 1.75'', Pro Comp 7005's 17x8 BS4.5, any time fogs, tailgate theft mod, led lights in the int., slim cubby HID headlights and fogs, TRD skid plate, bed mat
    i will be doing this soon, ooo yes i will be!!!!
  19. Mar 18, 2010 at 9:59 AM
    Nitrotim
    Nitrotim New Member
    07 SR5 Tacoma Access Cab 4x4
    347coupe whats that some place where you keep CHICKENS!!! LOL
  20. Apr 1, 2010 at 12:21 PM
    Logically Insane
    Wes
    TN --- USA
    This was very helpful.. I did this today in maybe 5 mins at the most..
    However, I noticed when I first cranked up afterwards some light came on the dash.. I think it was the check engine.. I drove to the store, went in to get a drink, and it was gone.. Anyone have this?
