FOG light mod Problem....
Discussion in '1st Gen. Tacomas (1995-2004)' started by RushTacoma, Apr 29, 2010.
  1. Apr 29, 2010 at 7:30 PM
    RushTacoma
    RushTacoma [OP] Toyota Member
    Jonathan
    OC, California
    2012 PreRunner
    I just did the fog light mod and now my front blinkers dont work out of the corner light, and I dont know why. I cut the green wires and swapped them and now I have my fog lights turning on when I turn my headlights on but when I use my signals only the rear lights signals and not my corner lights...Can anyone help me fix this problem?
  2. Apr 29, 2010 at 7:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I dont think you did it correctly. Did you follow the DIY in the Mods and Tutorial section?
  3. Apr 29, 2010 at 7:34 PM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    You should have only tapped into the green wire.
  4. Apr 29, 2010 at 7:35 PM
    RushTacoma
    Jonathan
    OC, California
    2012 PreRunner
  5. Apr 29, 2010 at 7:36 PM
    RushTacoma
    Jonathan
    OC, California
    2012 PreRunner
    I cut the green wire that goes to each light, then swap so the green that went to the front signal now goes to the corner light and vice versa
  6. Apr 29, 2010 at 7:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    My bad...Thought you were refering to the Second gen mod.
  7. Apr 29, 2010 at 7:38 PM
    RushTacoma
    Jonathan
    OC, California
    2012 PreRunner
    No problem. But yeah I'm talking about the 1st gen fog light mod.
  8. Apr 29, 2010 at 9:09 PM
    RushTacoma
    Jonathan
    OC, California
    2012 PreRunner
    WOW im so stupid! I just checked both bulbs in my corner lights and they are Burnt Black. Just got back from AutoZone with new lights and they work now (in hyper speed) but ill fix that later when I buy the Led Resistor.
  9. Apr 29, 2010 at 9:18 PM
    RushTacoma
    Jonathan
    OC, California
    2012 PreRunner
    Here's how it looks!
  10. Apr 30, 2010 at 6:37 AM
    Danosabre
    Dan
    Gardner,Ma
    09 TRD Off Road
    Me too. oops! :D
  11. Apr 30, 2010 at 6:37 PM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    Looks good!
    Does your state require corner lights for your truck to be legal?
  12. Apr 30, 2010 at 8:36 PM
    RushTacoma
    Jonathan
    OC, California
    2012 PreRunner
    I'm not completely sure but my corner lights are working now so no problem.
  13. Apr 30, 2010 at 10:48 PM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    Get 921 bulbs and put them in there. It will kill the hyper blink
  14. May 1, 2010 at 7:51 AM
    RushTacoma
    Jonathan
    OC, California
    2012 PreRunner
    921 bulbs in the corner lights? Ok I'll go try that. Thanks SRQ Taco!
  15. May 1, 2010 at 9:29 AM
    SRQ TACO
    Damon
    Sarasota, Florida
    Yeah autozone has amber ones. IDK about other places.
