Fog Light Mod
Discussion in 'Lighting' started by kristopherl, Oct 27, 2007.
  1. Oct 27, 2007 at 9:41 PM
    kristopherl
    kristopherl [OP] AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    For those of you who want to have your Fog lights on anyting you want and not just when your low beams are on then it is as simple as the following.
    Locate the Fog light relay in the engine fuse box. Remove the relay and turn it so that the spades are facing you. I made three short wires with a female and male end spade connectors. Attach the female ends to all the male spades on the relay exept the top left spade. Now take the male ends of those wires and plug them in to their respective locations on the fuse panel. Now make a longer wire with a female spade connector and attach to the top left position of the relay. Take the wire and feed it through the bottom of the fuse panel and run it along the wire housing to the front corner marker. Connect this wire to the hot lead and your done.
    I have seen other mods where they are connecting it to the EFI fuse... don't think this is a wise way to go. I heard that if you do the fog lights come on around 4 hrs later for about a minute.
    If you do it my way the fog light will operate just like your regular lights.. Fog lights will run if you want them to if you have just the running lights on or the low beams or the high beams. Also, they will turn off on there own when you turn off the ignition and open the door, just like your headlights.
    PS... Make sure you use the corner marker light... not the turn signal light. Unless you like a light show:)
  2. Oct 27, 2007 at 9:49 PM
    TuRDTACO
    TuRDTACO Carolina Alliance: Midwest Firearms Division
    joliet, il
    HAD 07 TRD OFFROAD PRERUNNER
    small dent on the hood, new foglight bulb, roughed up bedliner, been smoked in, suspicious stains on the passenger seat, boogers on the drivers seat, dirty floor mats, girl doodles on the dirty windows, loose wiring
    this sounds like a badass idea, i've always loved how my buddy's tahoe will run the foglights without the headlights on. so this really does work huh? i tried the black headlight mod and melted my headlight cuz nobody told me to turn the oven off before i stick it in there lol
  3. Nov 7, 2007 at 5:43 PM
    bao523
    bao523 Active Member
    houston, tx
    23 Tacoma Limited 4x4
    stock
    just finished the mod. took me about 30 mins cause i took my time and made it as clean as i could. very easy. thanks for the write up. it looks cool when i drive with just fogs on.
  4. Nov 7, 2007 at 9:39 PM
    TuRDTACO
    joliet, il
    i forgot about this thread lol but i did the fog light mod last week, and my truck looks badass now with the bhlm done and driving around with just the fogs on (they're both tinted deep yellow)
  5. Mar 13, 2008 at 9:13 PM
    subspd
    subspd King of used Toyota trucks
    Cumming, GA
    06' 4Runner Limited 4x4 V6
    Lift, lights, light saber..
    SO i tried the link to TN and none of the pictures worked??? Does anyone have a nice write-up with photos on the best way to get the Fogs to come on anytime?
  6. Mar 14, 2008 at 6:45 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    It's in the link in my sig.
  7. Mar 14, 2008 at 6:47 AM
    piercedtiger
    Jon
    Southern Tier, NY
    The way U did it there's only 1 wire, and they don't come on later.... :D
  8. Oct 19, 2013 at 8:25 AM
    shorephone
    shorephone New Member
    tacoma sport
    Exactly where is the relay, can't find that info.
