Fog Light Mod.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004Taco, Feb 27, 2010.
  1. Mar 5, 2014 at 8:49 AM
    #161
    Rubio92
    Rubio92 Well-Known Member
    Josh
    Bakersfield, CA
    '04 Prerunner IMPULSE RED
    Projector Retrofit in sig LED's galore inside and out Painted black stock alloys
    Ah. It makes sense now. I'm theory it should work. I imagine there's a relay deep beneath the steering column. Or behind the dash somewhere that would be easier. Thing is, I cut the wire pretty close to the base it was attached to and don't know if I would be able to go the same route. Have you disabled your DRL's?
  2. Mar 5, 2014 at 9:20 AM
    #162
    Rubio92
    Josh
    Bakersfield, CA
    I would then say trace the wire back a ways so that you can reattach it if anything happens that you don't want to happen. I snipped mine way too short and I can't use it.
  3. May 13, 2014 at 5:32 AM
    #163
    yourname
    yourname Member
    Josh
    Louisville
    02 tacoma prerunner, double cab
    HID PHILLIPS LIGHTS,
  4. May 15, 2014 at 8:07 PM
    #164
    ToyComa84
    ToyComa84 Well-Known Member
    Matt(hew)
    "flatland"
    03 prerunner sr5
    plasti dipped wheel caps,
  5. May 16, 2014 at 7:31 AM
    #165
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  6. May 16, 2014 at 4:32 PM
    #166
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    ok, so I did this mod a while back, switched to amber 921s in the corners and white 4157s down low. Installed resistors in the corners to stop the hyper-blink.. all is well.
    BUUUT I am constantly getting looks and "the bird" every time I make a turn!! obviously the 921's are no where near bright enough...
    the last few pages of this thread have me confused I guess...
    What is the brightest amber bulb that I can run in the corners? 360* leds?
    tia
  7. May 17, 2014 at 3:27 PM
    #167
    Rubio92
    Josh
    Bakersfield, CA
    There are no bulbs that are bright enough to be dedicated turn signals that are as small as 921/194's. Not that I know of at least.
  8. May 17, 2014 at 5:14 PM
    #168
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I need to do this
  9. May 17, 2014 at 5:36 PM
    #169
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Yes
  10. May 17, 2014 at 7:52 PM
    #170
    yourname
    yourname Member
    Josh
    Louisville
    They are CK, if you wanna do the mod trust me the bulbs will work perfect. The link I put to Amazon is the exact bulb I bought and the come with resistors so pretty good deal. Just wire a hot wire running from your side markers to the empty slot in the socket for the turnsignal. If you need me to post pictures of what I did to better understand I can.
  11. May 18, 2014 at 12:27 PM
    #171
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I'm good, just wanted to make sure as CK are differently wired. I have a spare set of sockets that I took the wires out and will use them:
  12. Sep 19, 2014 at 1:41 AM
    #172
    ToyComa84
    Matt(hew)
    "flatland"
    03 prerunner sr5
    yeah. any legal issues?
  13. Sep 20, 2014 at 7:32 PM
    #173
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    I know you can change the parking light (157) into a (1157) socket, but I ordered a LED amber color that fits my stock parking light. I'm thinking of switching my wires around, you know parking light wire to the front blinker and front blinker wire to the parking light, but is it possible if I can put a 18ga wire into the empty connector on the front blinker socket and run it back to the new blinker so it now become a parking light?
  14. Oct 13, 2015 at 9:48 AM
    #174
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Real easy but a very tight spot to work with.
