Fog Light Mod.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004Taco, Feb 27, 2010.
  1. Mar 1, 2010 at 9:59 AM
    t33gee
    t33gee aka Tg
    Tyler
    Riverside, CA
    03 prerunner
    k and n CAI, magnaflow exhaust, NOS
  2. Mar 1, 2010 at 11:32 AM
    BurritoJimmyFan
    BurritoJimmyFan Well-Known Member
    Frisco, TX
    04 Ext Cab TRD
    Gray Wire Mod, DRL Mod, Deckplate Mod
    Well, that is awesome! A few questions: are there any legal issues with not having the parking lights next to the headlights? Also, is there a better write up with step by step instructions and pics. Sorry, I am very technically challenged.
  3. Mar 1, 2010 at 11:45 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    LED resistor huh? Interesting term.
  4. Mar 1, 2010 at 12:00 PM
    t33gee
    t33gee aka Tg
    Tyler
    Riverside, CA
    03 prerunner
    legal issues? i guess ill find out if i ever get pulled over for it.
  5. Mar 1, 2010 at 4:46 PM
    747
    747 function > form
    1st Gen.
    Once I pulled my front parking lamps (corners), I saw the wiring loom (the black tubes). The looms looked like "T"s. I removed the tape, removed part of the "T"s, and cut the green wires, and reconnected the green wires (1st to 2nd, and 2nd to 1st). Then I replaced the "fog lamp" bulbs, and was set.
    What's it called.
  6. Mar 1, 2010 at 5:01 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    as for legal, in most states technically the new "turn signal" bulb will need to be amber not clear, but other than that it functions just the same.
  7. Mar 1, 2010 at 5:44 PM
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    2002 4x4 Limited TRD V6 Auto (234k+, 1-owner)
    Lots of small stuff; Grillcraft MX, Bilstein 5100's, Deck Plate Mod w/ AFE air filter, Airaid MIT, braided SS brake lines, Redline Tuning QuickLIFT hood struts, Extang Full-Tilt tonneau cover, fog light mod, gray wire mod, power outlets on-demand, Diff breather ext, additional contours to passenger side from oak tree.
    Is it possible to wire it up so that the existing light functions are switched (as described in this thread), but both sets are 'on' when the parking lights are turned on? So, all four would be light up when the parking lights are on, but the corners would then blink with turn signals or hazards?
  8. Mar 2, 2010 at 7:05 AM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    That's how I did mine. There's a how-to link down in the thread. It's a bit more involved than how they did theirs but I wanted to keep my corner lights.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/77890-first-real-mod.html
  9. Mar 2, 2010 at 7:55 AM
    bgdeer1
    bgdeer1 Well-Known Member
    minooka il
    tacoma prerunner
    3 inch lift in back 1 1/2 front. 31' mesa A/T's. Alpine deck, alpine speakers, l5 kicker solo baric sub
    dumb question. When you pull the light off and cut n swap the wires, how do you turn them off n and >?? do they turn on when your headlights are on orr whatt... im sooo confused
  10. Mar 2, 2010 at 8:53 AM
    t33gee
    t33gee aka Tg
    Tyler
    Riverside, CA
    03 prerunner
    i wanted to do it like that but i got confused, maybe if i can actually figure it out ill go back and change it.
  11. Mar 2, 2010 at 8:59 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    In my state (Utah), technically, this wouldn't be legal to do. Fog lights and turn signals would be ok (assuming one changed the bulb on the turn signals to amber). There would need to be marker lights installed since those are now missing. Probably be ok with running another bulb to the cornering lights thats wired to your parking lights. The link above would technically how it should be done to stay legal.
  12. Mar 2, 2010 at 9:21 AM
    SunDevilTacoma
    Doug
    Gilbert, AZ
    they turn on and off with the parking lights, at least mine do.
  13. Mar 2, 2010 at 9:25 AM
    t33gee
    t33gee aka Tg
    Tyler
    Riverside, CA
    03 prerunner
    same here. and sundeviltacoma, you gotta make a step by step vidon how u got the actualt parking light lights to stay on with the new fog lights. i read that link but i gguess im just not that smart to understand it. :D
  14. Mar 2, 2010 at 9:37 AM
    SunDevilTacoma
    Doug
    Gilbert, AZ
    step by step vid?? hell, i'm not that good! besides, i had to read it like 20x myself before i fully understood everything. :D read it a few more times, take your time, once you get into it it'll make sense.
  15. Mar 2, 2010 at 5:21 PM
    #35
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    SunDevilTacoma;
    Okay . . . I'm a dumbass. I've read your thread along with the link provided and I can't seem to get it. It seems to me the 4x4wire link is about eliminating the lower blinkers and utilizing the corners for both parking lights and blinkers. You integrated both sets of lights (turning on with parking light controls) while still having the corners act as turn signals. I know you didn't sign up for a teaching position here, but would you mind typing up a quick & dirty description of how the respective wires are cut/spliced/connected? No need to worry about types of connectors or sockets, just a brief rundown of how the wires are done.
    EDIT:
    Okay, I think I may have it. I must not have read it the full 20 times as recommended...
    You wired up the two greens to the two socket wires (brighter for blinkers). The two whites run together to the ground tab on the socket. In addition to the above, you kept the white running down to the OEM blinker and the green wire from the corner light down there as well?
  16. Mar 2, 2010 at 5:32 PM
    #36
    t33gee
    t33gee aka Tg
    Tyler
    Riverside, CA
    03 prerunner
    I think we should send sundevil some cash thru paypal for his trouble hahaha
  17. Mar 2, 2010 at 5:39 PM
    #37
    Quills
    Quills Well-Known Member
    Rodney Dinkens
    Marcy Projects, Bed-Stuy, BK son...
    de-vin'd
    Removed the steering column surround and the keyed ignition.
    You're going to accidentally set your truck on fire.
  18. Mar 2, 2010 at 6:14 PM
    #38
    747
    747 function > form
    1st Gen.
    If so, post pics or a video.:eek:
  19. Mar 2, 2010 at 6:28 PM
    #39
    747
    747 function > form
    1st Gen.
    1st, fog lights; 2nd, headlights. No pic with them off...imagine darkness.
  20. Mar 2, 2010 at 6:28 PM
    #40
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    Damnit . . . not again...:bananadead:
