Fog Light Mod.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004Taco, Feb 27, 2010.
  1. Dec 30, 2010 at 11:02 AM
    #81
    asoccerwannabe
    asoccerwannabe Member
    02 PreRunner 6cyl DC
    Quick question for anyone who's done this mod: how well do the 1157's or 1157A's actually cut the fog? I know that a lot of "fog lights" stock or aftermarket, don't really do anything but look cool; I'm looking to get something that does the trick.
    And what about changing lenses? I've seen a lot of people saying the stock lenses arent able to support such intense heat.
    Anybody able to speak to this?
    Thanks!
  2. Dec 30, 2010 at 11:15 AM
    #82
    bgdeer1
    bgdeer1 Well-Known Member
    minooka il
    tacoma prerunner
    3 inch lift in back 1 1/2 front. 31' mesa A/T's. Alpine deck, alpine speakers, l5 kicker solo baric sub
    one thing i noticed when i did this mod was that my old turn signals which are now the fog lights were orange bulbs. So i went to autozone and bought regular bulbs, the only thing is that now after the mod i noticed my fog lights arent that bright.. Is the brightness dependant on the bulb? SHould i get certain bulbs? which ones?
    Another thing, my turn signal is now very dull n a small blinking light located in the headlight.. When turning during day time you cant see it, anyone have this problem?
  3. Dec 30, 2010 at 3:31 PM
    #83
    Ritter
    Ritter Well-Known Member
    David
    Atlanta/ Nassau
    08 Taco Crew TRD and 03 Xtra 4x4
    I'm only interested in having the new "fogs" act as fogs and leave the blinking to the new clear corners I just ordered.
    What bulbs can I use to match the 6000K my HID Xenon headlights- 6000K H1's?
  4. Jan 19, 2011 at 9:34 PM
    #84
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    I think I'm gonna try this over the weekend. So is there any parts that need to be bought to make this legal and perfect. I know there's the LED resistor to eliminate hyperblink, what about bulbs. Just wanna make sure i get everything done in one try.
  5. Jan 19, 2011 at 9:48 PM
    #85
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Need amber bulbs for the corner lights.
  6. Jan 22, 2011 at 11:36 AM
    #86
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    Does anyone know the part numbers, brand or whatever for clear Turn signal bulbs and amber clearance light bulbs to where I could do this mod?
  7. Jun 17, 2011 at 1:01 PM
    #87
    SoftShellTaco
    SoftShellTaco Well-Known Member
    Justin
    Goldsberry, NC
    SR5
    I did mine just a tad bit different. I ran a splice off the corner light and used that as a signal to a relay, then grounded the relay to the frame. Then ran 12VDC to the relay and a splice to each unused slot on the turn signals(they are a dual filament bulb factory). I then changed the bulb to white and put yellow tint over the housing. They aren't as bright as the upgrades you guys have done but it looks kinda cool.
  8. Jun 17, 2011 at 1:06 PM
    #88
    SoftShellTaco
    Justin
    Goldsberry, NC
    SR5
    The bulb you ran is not that bright, along with that it doesn't get as hot either, the brighter the bulb the hotter the bulb and our housings are plastic so you run the risk of melting them. I know this because I did this DIY mod on a friends DC long before I ever bought mine and a few weeks later he came by and said his bulbs blew out and his housings were black(factory clears mind you). I took it apart and they had melted everything inside, he wanted to use a H3 6500k Xenon light but I told him not too.......then he did and that was the result. Just be careful I would say run LEDs if you want brighter with none of the added heat but the illuminating distance will be shorter.
  9. Jun 17, 2011 at 1:08 PM
    #89
    SoftShellTaco
    Justin
    Goldsberry, NC
    SR5
  10. Aug 1, 2011 at 8:12 PM
    #90
    Taco GTR
    Taco GTR Valdosta State University
    Orrin
    Shadydale/ Valdosta
    2003 Tacoma reg cab.
    Bone ass stock, 2nd air filter delete, JVC head unit, Alpine 600watt amp, JVC 1600 watt 12'' sub, Tractor Supply Company Toolbox, ALOT MORE TO COME.
    ok. is there anyway to do this mod BUT still allow the regular turn signals to flash?? i really wanna do this mod. with the bulbs i already got cause the amber would set off my hids
  11. Aug 11, 2011 at 12:41 AM
    #91
    52419
    52419 Well-Known Member
    someplace
    03 tacoma lifted 6in on 35s
    fabtech 6in lift, 35.12.50.16s,on mt classics
    #91
  12. Aug 11, 2011 at 8:46 AM
    #92
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    So I tried to do this mod yesterday. Followed the "easy" method to a T, took my time and made sure of good crimp connections; tested it, and NOTHING worked!!:confused:
    neither the parking light or blinker would light up at all, and the blinker indicator on my dash stayed on and would not turn off.
    I switched the wires back and now the blinker works, but the parking light does not work. Looked at the bulb, its fine..
    I didn't have any 12/14 guage wire to use as an extension and used 16guage... could that have been the problem?? I'm usually good with wiring but I'm totally stumped here
  13. Feb 16, 2012 at 5:05 PM
    #93
    gacandido2010
    gacandido2010 Well-Known Member
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    Bilstein 5100s, Eibach Coils, All Pro Baja Leaf Pack, Fox 2.5x16", All Pro 1.5 spacers, Deckplate Mod, K&N Filter, Magna-Flow Exhaust System, Cobra Ultra Cb with 3" Firestick, 2 Hella 500 HIDs, custom mesh grill, blacked out lettering, Limo Tint, Fog Light Mod
    did this shit lastnight drunk with my buddies haha
    easiest mod you just have to take ur time cutting the wires and leaving enough room to swtich them
  14. Feb 18, 2012 at 5:00 AM
    #94
    lonniea
    lonniea Well-Known Member
    Lonnie
    Monroe LA
    02 tacoma dc sr5
    add a leaf and uninstalled for rebuild fabtech coilover set at 3 inch foglight mod keyless entry deckplate soon leer shell
    cant get a pair to last they burn out pop resistor i just put the bliker bulbs back in super bright orange fog lights haha
  15. May 27, 2012 at 2:31 PM
    #95
    zaoc
    zaoc Well-Known Member
    Texas
    02 PreRunner
    fog light mod spray painted rims
    anyone have trouble with the blinkers not working after this mod? all I did was the simple green wire switch but now the (corner)blinker won't work.
  16. Aug 9, 2012 at 3:14 PM
    #96
    tacomamike
    tacomamike New Member
    could anyone tell me how i would wire the fog lights up to a separate switch that isnt on the park light switch so i can turn them on when ever with out having thee fogs and my headlights on at the same time
  17. Aug 9, 2012 at 5:52 PM
    #97
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    are these even "fog" lights? i thought they were just running/marker lights?
  18. Aug 9, 2012 at 6:28 PM
    #98
    jblaze805
    jblaze805 Well-Known Member
    Ventura/Fresno, CA
    04 trd pre-runner
    2.5" king coilovers, caburg uca, magnaflow exhaust, aem intake
    To me it doesn't serve a purpose just gives it the cool factor. 6k corner and fogs, 5k FX-R projectors.
  19. Aug 24, 2012 at 3:40 PM
    #99
    02tacoME
    02tacoME Active Member
    Mick
    Maine
    02 Tacoma
    de-badged, aux reverse lights, fog light mod, deck plate mod, tinted and yellow fogs, blacked out corner lights and painted headlight assembly
    I did this mod and swapped the bulbs and it turned out great! the rapid blinking is no bother to me im sure ill get used to it.
  20. Sep 4, 2012 at 6:12 PM
    #100
    626TACO
    626TACO Active Member
    SoCal
    01 PreRunner SR5 V6
    I did the simple T way with the 921s and everything worked fine. But when I hit the brakes while signaling I get the hyper blink effect. Did I do something wrong???
