Fog Light Mod.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004Taco, Feb 27, 2010.
  1. Sep 6, 2012 at 7:35 AM
    #101
    06yfz450ridr
    06yfz450ridr Well-Known Member
    Austin
    CT
    HID's
    thats weird must be grounding somewhere.
    but by far the easiest way to do this mod is to just switch the wires around like i did. you just need to extend the running light wires to reach the bottom. wish i could throw my 3000ks in them without melting them but there is really no reflector in them anyways.
  2. Oct 29, 2012 at 10:01 AM
    #102
    MT4banger
    MT4banger Member
    Brandon
    Bozeman, MT
    02 SR5 4x4
    5100s @0" Toytec Eibach coils and 5100s on rear w/ 2" AAL, 1.25" Spidertrax wheel spacers up front, Deck plate mod, Fog light mod, 2 1/4" catback exhaust, DougThorley Headers, Truxedo lo-profile tonneau cover, Rhino ben liner, Tow package, Step rails, Tinted windows, Kenwood KBX-800 deck, Kenwood 1000amp, JL 10" sub w/ Stealth box,
    I had great success with this mod using Beau02's write up. only hyper blinks if one of the grounds get loose on the new turn signal sockets so be sure to secure those.
    For the bumper lights (the old blinkers), i found some nice bright yellow bulbs on ebay to put in em so they could actually function as fogs. looks great and would like to keep them in but the only problem is i need to wire in a switch to control the bumper lights manually otherwise if their on when weather isn't permitted, you'd get pulled over. so because of that i got the clear bulbs in as DRLs.
    Anyone know how to wire in a rocker switch with the fog light mod??
    I'm guessing a relay has to be thrown in there maybe?
  3. Nov 2, 2012 at 12:36 PM
    #103
    01kingtaco
    01kingtaco Well-Known Member
    Kodiak
    Maui hawaii
    01 taco slightly modded
    Bigger tires, sound system, deck plate mod, fog light mod, straight pipe exhaust, blue led floor lights, ultragauge, 3 inch lift
    Going to do this on my 01 tonight just gota buy some amber 921s' and some clear bulbs for the fogs, what's the number for the bulbs in the old turn signal lights?
  4. Nov 2, 2012 at 1:56 PM
    #104
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    I did it the EASIEST way ever. Got some clear bulbs for down low installed those. After that I simply swapped the wiring from the corners to the blinkers. DONE
  5. Nov 2, 2012 at 11:46 PM
    #105
    01kingtaco
    Kodiak
    Maui hawaii
    U got the hyper blinking still? I'm gana do the exact same but put 921s amber bulbs in the old corner markers
  6. Nov 4, 2012 at 4:39 PM
    #106
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    I just used the stock bulbs in the corners. I had same size in my box I put amber ones in there. For the valance I have a clear bulb in it. Not hyper blink with regular bulbs
  7. Nov 8, 2012 at 10:20 PM
    #107
    01kingtaco
    Kodiak
    Maui hawaii
    Do they even make a 921 amber bulb cuz i can't find one anywhere
  8. Nov 9, 2012 at 1:39 PM
    #108
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    The silver star ones are white-amber
  9. Nov 9, 2012 at 6:28 PM
    #109
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yes. Sylvania part# 921NA LL
  10. Nov 9, 2012 at 6:49 PM
    #110
    JaimeSR5
    JaimeSR5 Well-Known Member
    Jaime
    Fontana
    03 PreRunner-4Banger
    K&N filter,-JDM tailights, NGK Spark Plugs, 6k H.I.D head light kit, fog light kit
    the mod runs like the dtr lights just like it would be stock they turn off as soon as you open your door when the engine is off. Im looking forward to doing this MOD tomorrow morning :D
  11. Nov 9, 2012 at 6:56 PM
    #111
    JaimeSR5
    Jaime
    Fontana
    on my corner lights I have L.E.D. light bulbs on there are pretty bright lol take a good look into the bulbs I would have gone silvanias but I found the L.E.D.'s at a good bargain so i didnt pass it
  12. Nov 10, 2012 at 9:00 PM
    #112
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
  13. Nov 11, 2012 at 5:31 AM
    #113
    Backinblack03
    Backinblack03 Well-Known Member
    Brian
    VT
    2003 Xtra cab 4x4 2.7/5spd
    ABS sucks.
    In this video here, what other lighting modifications have been done? The delay back to white from blinking is not typical of switchback LEDs I've worked with in the past. Do you have a timed missing-pulse circuit in there somewhere?
  14. Nov 12, 2012 at 6:08 PM
    #114
    JaimeSR5
    Jaime
    Fontana
    did the cruise light switch today, only issue is the Hyper corner lights but they look so damn cool hahahahaa
  15. Nov 12, 2012 at 9:56 PM
    #115
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    How do u make yellow
  16. Nov 12, 2012 at 11:01 PM
    #116
    01kingtaco
    Kodiak
    Maui hawaii
    Put 921 bulbs in ur new signal markers and ur hipper blinking will go away
  17. Nov 13, 2012 at 4:41 AM
    #117
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    I have the small numbs that are in the side markers. No hyper blink
  18. Nov 13, 2012 at 5:51 PM
    #118
    JaimeSR5
    Jaime
    Fontana
    there is a 921 bulb on the driver side from the car accident :eek: I had a few months ago, I had L.E.D. bulbs on both sides but with the fix I got different bulbs put in to the corner light and my headlight. I had an H.I.D. bulb on aswell but that got messed up need a new kit might go with a different brand.
  19. Nov 13, 2012 at 5:52 PM
    #119
    JaimeSR5
    Jaime
    Fontana
    lol whats with that kind of question hahahahahaaa specify it up a little more bro.
  20. Nov 13, 2012 at 5:56 PM
    #120
    TacoSkeet
    TacoSkeet 'MERICA
    Steven
    Memphis, TN
    03 DC Tacoma
    My buddy had the hyper blink only when he pushed the brake in, and mine had hyper blink even with the 921s. A simple LED resister from Autozone fixed them both. I think they are like 5 bucks each.
