Fog light pre wired models
Discussion in 'Technical Chat' started by bababoy, Apr 18, 2015.
  1. Apr 18, 2015 at 12:25 PM
    bababoy
    bababoy [OP] Member
    Tacoma SR5
    Hello.
    I'm wanting install fog lights on my 2014 double cab sr5. I've done a search but can't seem to find info if this model is pre wired for the fog lamps. Would anyone out there confirm if it is so? If it is, then all I need is the switch and lights?
    Thanks a lot.
    Ps. 1st tacoma so noob. Thanks in advance! Cheers.
  2. Apr 18, 2015 at 2:05 PM
    bababoy
    bababoy [OP] Member
    Tacoma SR5
    All good found my answer. Tnx tw.
  3. Jun 2, 2015 at 6:37 PM
    Lance R.
    Lance R. Member
    Lance
    2013 tacoma double cab pre runner
    None yet
    Was yours pre wired? If so what did you need to get it working? Mine is pre wired but im not sure if all i need is a switch and the lights or if there is more to it than that?
  4. Jun 24, 2015 at 9:56 AM
    bababoy
    bababoy [OP] Member
    Tacoma SR5
    Yup it's pre wired. I only had to plug in the relay, switch and lights.
  5. Jul 6, 2015 at 1:43 PM
    offthewallsurfer
    offthewallsurfer Well-Known Member
    What was the part number on those lights and switch?? I'm looking to do the same on my 2014 prerunner, I'd like to also install the back up camera too, I think it might be Pre wired too because the touch screen pops up with a warning to check surroundings.
  6. Jul 22, 2015 at 10:32 PM
    bababoy
    bababoy [OP] Member
    Tacoma SR5
    Sorry for the super late reply. I just went to the dealer and got it from them. Then I bought them on eBay and Amazon
  7. Jul 22, 2015 at 10:34 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Are you pre wired for fogs? Do you have a 2.7 i4 or 4.0 V6?
  8. Jul 23, 2015 at 4:42 AM
    offthewallsurfer
    2.7L i4
  9. Feb 9, 2016 at 5:24 PM
    PainaBoi96797
    PainaBoi96797 Member
    2014 White Tacoma Double Cab SR5
    Color-Matched: Bumper, Door Handle 5% Tint all around Pop N Lock Automatic Tailgate Lock (Works with Key Fob) TruXedo LoPro Tonneau cover Red LED Interior Lights Police Chirp/Siren
    @offthewallsurfer where were your wire harness wrapped up/tucked away. I have a 2014 Double Cab SR5 and looked everywhere but can't seem to find any wire harness. I didn't check to see if there was the switch wire in the cab yet. Also, where did you plug your relay??? When looking at other post, there seems to be a secondary fuse box right next to the big, main fuse box under the hood that holds the relay for the fog lights but when I looked under my hood, I only have the one big, main fuse box. Please advise at your earliest convenience and if could, post some pictures??? Mahalo nui loa
  10. Feb 9, 2016 at 5:24 PM
    T4RFTMFW
    Are you a V6 or a 4 cylinder?
  11. Feb 9, 2016 at 5:25 PM
    PainaBoi96797
    I am a 4 cylinder. 2.7L i4
  12. Feb 9, 2016 at 5:25 PM
    T4RFTMFW
    You won't be prewired for fogs, you should be for the back up camera.
    Connector behind the bumper to the center right side (passenger side).
  13. Feb 9, 2016 at 5:25 PM
    T4RFTMFW
    You are not pre wired and will need to purchase the full kit I linked to.
  14. Feb 9, 2016 at 5:26 PM
    T4RFTMFW
  15. Feb 9, 2016 at 5:29 PM
    PainaBoi96797
    Thanks for the information and quick response. That a shitty deal. My truck had the reverse camera when I bought it from the dealer. I was pre-wired for the sideview mirrors with the turn signals (which I did the 4runner mod) and was hoping I would be wired for the fogs lights. Ah not to worry, I was going to buy the whole kit from the get go when I couldn't find the wire harness. Also I did go the to link and they are sold out. Contacted John, sales person, and he sold the last kit. Seems like the fog light kits are discontinued. There are only a few left from ebay if they still have it. Thanks again @DCSBFTMFW Mahalo nui loa from Hawaii
  16. Feb 9, 2016 at 5:30 PM
    T4RFTMFW
    Welcome, you should be able to cross reference that part number into Google and find someone with the kit in stock.
    Aftermarket kits with harnesses are also available (and cheaper), but aren't OEM quality.
    No 2.7 trucks are prewired for fogs, unfortunately!
  17. Feb 10, 2016 at 8:25 AM
    The Streak
    The Streak Member
    Tim
    New York
    2013 Silver Streak
    There are several aftermarket Fog Light Kits available and reasonably priced. I bought one and am happy with it.
    It did not come with instructions, but there is a lot of information on this site to help sort it out.
    hobiecat111629 likes this.
