Fog Light problem 2nd Gen
Discussion in 'Garage / Workshop' started by elliott.estes, Dec 18, 2009.
  1. Dec 18, 2009 at 7:52 PM
    elliott.estes
    elliott.estes [OP] Well-Known Member
    sacramento
    07 Black DC TRD Sport
    In Dash Avic-D3 / Blacked out headlights / Satoshi Grille / OME 90000 Front Shocks/ OME n182 Rear Shocks / OME 885 Coils / AAL with TSB's / 10MM lift Enhancer Kit / Light Racing UCA's / BFG AT KO's (285x70x17's) / Procomp 7089 Rims
    Hey guys yesterday I removed my headlights and painted them black and put them back in and now one of my fog lights is not working. Maybe it's a random and the light burnt out but it just seems strange. The truck is only 2 years old.
    thanks
  2. Dec 18, 2009 at 7:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check the connections, then check the bulb. If you touched the bulb with your fingers, chances are, it burned out.
  3. Dec 18, 2009 at 8:00 PM
    elliott.estes
    sacramento
    i did it seems to be in good. I didn't remove the fog lights, but maybe my arm moved the wire around while I was reaching for a really high bolt on the side of the head light.
    Hey Chris I was trying to remove the connection and then reconnect it, but was unsure how. Do you know how?
  4. Dec 18, 2009 at 8:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You have to squeez the sides, and pull out iirc.
  5. Dec 18, 2009 at 8:10 PM
    elliott.estes
    sacramento
    What part is the iirc, the blue plastic part or the actual wire going into the light. I have to go to work but will try tomorrow. Thanks
  6. Dec 18, 2009 at 8:28 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    IIRC= if i remember correctly
    its not an actual piece
  7. Dec 18, 2009 at 8:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thanks Jamie. :eek:
  8. Dec 21, 2009 at 6:25 PM
    elliott.estes
    sacramento
    I attempted a few times to squeeze the sides but I am unable to remove it. Have you seen any photos on line that you could direct me to so i can see exactly what I need to do.
    thanks
  9. Dec 21, 2009 at 6:49 PM
    elliott.estes
    sacramento
    i just gave it one more attempt and I got it out! The bulb needs to be replaced!
  10. Dec 21, 2009 at 6:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear you got it! :)
