Fog light question, Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drade, Nov 6, 2010.
  1. Nov 6, 2010 at 7:40 AM
    drade
    drade [OP] BRUINS 4 LIFE
    ME
    2016 Toyota Tacoma TRD Off Road Short Cab Silver
    TRD PRO skid plate, wet kole seat covers, tint all around, red line tuning quick Lift system, paint protection film, gloss blacked out OEM emblems, electric start, heated seats.
    Hey guys, well I want fog lights :). I would prefer toyota fog light kit, but I cant find a whole set. These are the two that I found. And by the way, I have an 07 base model and it has the slots for the fog lights, are there any specific kind of bolt pattern I need?
    Here are the two kits:
    Solara kit at 168$- http://cgi.ebay.com/ebaymotors/TOYO...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    My favorite color (kit)! 120$
    http://cgi.ebay.com/ebaymotors/YELL...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    Which is better, and am I looking in the right direction? Is aftermarket reliable, when it comes to electronics im really picky. Thanks tacoma enthiusists.
  2. Nov 6, 2010 at 7:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Find some fogs from a Tacoma. You need the Fog lights, the switch, and the relay. The wireing should be in place.
  3. Nov 6, 2010 at 8:24 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Yup! If you have a V6, the wiring should be there...taped or somehow fastened in the back side of your bumper. The harness is probably ended in your dash behind where the switch would go. Just gotta find 'em.
    4 cylinder.....no such luck. I had to install everything.
  4. Nov 6, 2010 at 8:29 AM
    Poorboy7
    Poorboy7 Member
    Central Coast, CA
    06 Single-Cab Pre-runner 4cyl.
    Leer Shell,Surf Racks Just Clean and Black!, Stock, but still get looks? What?!, Toytec OME 3'' Front w/add-a-leaf rear,And one hot 3 year old Australian Shepard rollin hard son!
    I Installed some after market piece of shit fog-lights I bought off E-Butthole-Bay and after 6 months of working properly they took a dump on me. Im going to replace them with Toyota ones.
  5. Nov 6, 2010 at 8:35 AM
    drade
    ME
    ^^ Yea im not going to get aftermarket, cant trust it. Where could I get the relay and the switch, I can buy the lamp and bulbs of my buddy for around 130$.
  6. Nov 6, 2010 at 8:38 AM
    drade
    ME
    I do have the v6, And I would love to check to see if the wiring is there. I will do this and get back to you. And how hard is it to hook these baby's up using the wiring.
  7. Nov 6, 2010 at 9:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Everything plugs right in. The worst part is cutting the zip ties holding the wire harnesses in place :)
  8. Nov 6, 2010 at 10:37 AM
    drade
    ME
    Thats what I have read. I got the fog lights off my buddy. Its a set of original toyota fog lights left and right, and came with two bulbs and the back. All I need is a switch, and a relay? Don't I need wire to go from my fog lights to the prewired wires? And where can I get a switch and a relay?
  9. Nov 6, 2010 at 12:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can get the switch from Ebay or the dealer, and the relay can be found at any auto parts place. All the wiring should be in place.
  10. Nov 6, 2010 at 1:06 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    I don't get the whole fog light thing. Generally, their beam patterns are useless at anything above a walking speed and when used in wet conditions, they simply cause glare for oncoming drivers. You're far better off with driving lights that have a longer reach with a pencil-type beam. People turn on fog lights because they think they it makes them look special... well... I got news. Fog lights on for no reason make you look stupid to anyone who knows a bit about lighting. Check out http://www.danielsternlighting.com for the straight story on lights.
  11. Nov 6, 2010 at 1:33 PM
    drade
    ME
    Thank you I got the parts on order. I do notice it is plug and play, which is cool. You just hook the wiring harness in the back of the fog lights. But the only question is, how easy is it to set up the fog light switch and the relay? Is there a nice instruction manual for a prewired base model tacoma? Thanks!
  12. Nov 6, 2010 at 6:38 PM
    pinktaco808
    pinktaco808 Hot Steppa
    what about us based need wiring write up
