Fog Light Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Munnyshot, May 9, 2017.
  1. May 9, 2017 at 1:07 AM
    Munnyshot
    Munnyshot [OP] Active Member
    Lakewood, CA
    2018 SR5 DCSB 2wd
    Im sorry if this seems like a dumb question, but i just changed out all of my standard bulbs for LEDs and I was testing out the fog lights when I noticed that they only come on if the headlights are already on and, also, they turn off when the high beams are pushed on. Is this normal?
    I thought they would just turn on and off when you press the switch on the dash.
    Just an observation.
  2. May 9, 2017 at 1:46 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    That's the way they are suppose to work.
    Search for fog lights anytime mod if you'd like to wire things so the fogs come on anytime you press the button.
    Norton likes this.
  3. May 9, 2017 at 1:54 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Perfectly nermal
    RigginsTaco likes this.
  4. May 9, 2017 at 4:08 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    DVexile[QUOTED] likes this.
  5. May 9, 2017 at 8:58 AM
    Munnyshot
    Lakewood, CA
    2018 SR5 DCSB 2wd
    Thanks guys
  6. May 10, 2017 at 12:08 PM
    Crushabug
    Crushabug Active Member
    2013 Tacoma TRD OFF-ROAD 4X4
    I did the fog light anytime mod and the bed plug now no longer works?? Coincidence? How can I reset?
  7. May 10, 2017 at 12:14 PM
    DVexile
    Ken
    Not a coincidence I think. If I recall correctly the wire for the AC converter relay is right there by all the others related to this mod. Over the years that fuse/relay box has changed a few times along with the wire colors - also some of the spare taps referred to in the "easy" mod page don't exist in later models.
    Anyway I'd try to find an appropriate wiring diagram or just look at the fuse box diagram for the relay related to the AC converter and check the wiring in there.
  8. May 10, 2017 at 12:16 PM
    DVexile
    Ken
    Oh and when I did my mod I in fact tapped the AC inverter relay. It can be confusing which is ground and which is 12V. See this post: Diet Taco... trying to keep things light from my build thread which shows the wiring in the 2015 which is probably really similar to your 2013.
