Fog Light Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by behls, Oct 5, 2017.
  1. Oct 5, 2017 at 3:11 PM
    behls
    behls [OP] Well-Known Member
    Dave
    Lehigh Valley, PA
    2017 SR5 DCSB Quicksand
  2. Oct 5, 2017 at 3:12 PM
    behls
    Dave
    Lehigh Valley, PA
    Can someone link me to an affordable LED fog bulb that will work in my 17 SR5.
  3. Oct 5, 2017 at 3:27 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    If the stock fog lights work then you may have a couple of defective bulbs. Is it possible to plug them in reversed? Rotate the connector 180 then try plugging them in again. Led's only work in one direction.
  4. Oct 5, 2017 at 3:29 PM
    behls
    Dave
    Lehigh Valley, PA
    They only connect one way truly, they won't clip in solidly if they're not the right direction.
    I'm reading now on some 4runner forums now that the new style of H16's are actually not what run in the third gens. That you need to put the H11's in?! Any idea? I've tried two different sets of the H16's from two different brands and neither work.
  5. Oct 5, 2017 at 5:09 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Check around page 578 of your manual... it will tell you what bulbs are stock on yer truck...!! Replace with same type..!!
    shakerhood and Baerskin like this.
  6. Oct 5, 2017 at 5:39 PM
    behls
    Dave
    Lehigh Valley, PA
    no shit. thank you for providing me with such articulate insight. it's page 580.
    I need normal H16's. 19 Watt? What is the LED equivalent of a 19 watt halogen?
  7. Oct 5, 2017 at 5:46 PM
    over60
    Muskoka, Ontario
    You are very welcome...!! It's page 578 in my Sport manual, so that's why I said to look in that general area...
    Anywhoooo, I'd suggest that LED's are no freakin' good as fogs anyway.....they do not throw a nice beam.... they spray light...
    You will not like them, I'm sure.... On-coming vehicles may not like them either........Good luck my friend..
  8. Oct 5, 2017 at 5:48 PM
    behls
    Dave
    Lehigh Valley, PA
    hell you're probably right. short fuse on this issue at the moment. appreciate the thoughts.
    over60[QUOTED] likes this.
  9. Oct 5, 2017 at 9:07 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    if you want LED fog lights. You might be better off getting some that have there own dedicated housing. Kinda like the TRD Pro has.
  10. Oct 6, 2017 at 12:23 AM
    4x4yotaphan
    4x4yotaphan Well-Known Member
    SoCal
    SOLD: 2016 White TRD Sport DCSB 4x4
    Exterior: King suspension w/compression adjusters Icon billet UCAs Icon 3 leaf expansion pack Timbren rear bump stops w/U bolt flip kit Wheeler’s Offroad front superbumps BFG KO2 285/70/R17 on SCS Ray 10 17” wheels w/black wheel lock lug nuts TRD Pro grill TRD Pro taillights TRD Pro skid plate Demello Offroad front bumper Smittybilt XRC 9.5 comp winch w/Factor 55 fairlead and Flatlink E RCI LCA skids Beast Fab rock sliders 4 Extreme LED 4” pods Baja Design Squadron SAE LED amber fog lights Relentless Fab bedrail mount w/KC Flex dual amber chase lights AVS vent visors Interior: TRD Pro shift knob OEM instrument switch panel conversion (from 3 to 5 slots) Taco Garage DMM with Scosche Magicmount Upgraded Kicker sound system Husky X-act floor liners Performance: Airaid cold air intake system Pedal Commander w/Bluetooth
    Like someone said earlier you need to reverse the plug. Sometimes it doesn't clip in like the OEM ones because the aftermarket manufacturer made theirs with reversed polarities. My high beam leds are like that, at least try it out and you'll see if that's the real case. It won't break anything so worth a try.
  11. Oct 6, 2017 at 4:13 PM
    DeadEyeWI
    DeadEyeWI Fight for your 2A right
    WI
    I've been really happy with these:
    https://www.tirerack.com/lighting/detail.jsp?ID=2630&brand=Philips
    And they're plug and play. I mean its pretty straight forward snap-in.
    3yr warranty and from a known company.
    6000k so they compliment the headlights I installed as well.
    I got them in both cars and the beam is nice and wide and they are designed to not blind oncoming traffic:
    "Philip's patented SafeBeam technology creates a similar beam pattern as a halogen fog lamp with the light being directed towards the road ahead for maximum safety."
  12. Oct 6, 2017 at 6:20 PM
    My Truck
    My Truck Well-Known Member
    Bay Area, CA
    2016 SR DCSB 4x4 Super White`
    Any output shots of those?
  13. Oct 7, 2017 at 4:57 AM
    Steig
    Steig Well-Known Member
    Tacoma TRD off road
    Good info ! Thanks, I may give them a try
  14. Oct 7, 2017 at 9:29 AM
    justin808
    justin808 Well-Known Member
    Bay Area, CA
    2017 TRD OR 4x4 DCSB
    Kings, Icon UCA, 275/70 K02s
    i've used H11s in my fogs and they work great. the same bulb as the low beams.
  15. Dec 7, 2017 at 9:21 PM
    Texas2016Taco
    Texas2016Taco Well-Known Member
    Oscar
    San Antonio, TX
    2016 Tacoma SR5 V6
    16 dcsb SR5, 17in MB wheels 265 KO2, ReadyLift SST Kit, AFE CAI, N-Fab side steps, Opt7 H11 HIDs
    I did the same thing and they ended up shorting out my wiring harness after a couple months. I put the original factory bulbs back in and luckily the dealership replaced the wiring free. But the tech could tell what I did and warned me not to use H11 bulbs because of the different wattage. FYI...
    over60 and justin808[QUOTED] like this.
  16. Dec 7, 2017 at 10:03 PM
    BeaverNation
    BeaverNation Well-Known Member
    That's because you have 19 watt fogs. I run 60w h11's, because my stock fogs are 55w
    over60 likes this.
  17. Dec 8, 2017 at 3:57 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    What do you mean by shorted out the wiring? The fogs have a fuse and that would fail before the wiring could get damaged. Did you melt the connectors on the bulbs?
  18. Dec 8, 2017 at 6:03 AM
    TUDBALL
    TUDBALL Active Member
    Newhall, Ca.
    arnette64 and Baja Designs like this.
