Fog Light Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by K9TXS, Dec 16, 2021.
  1. Dec 16, 2021 at 9:11 AM
    K9TXS
    K9TXS [OP] Well-Known Member
    Clarksville, TN
    I will replace my fog lights in the near future.
    The install brackets that come with the Baja lights do not appear to be adjustable. I would like to angle them slightly to show the edge of the road a little more. I don't need them to be angled a lot like ditch lights, but a slight angle would be good.
  2. Dec 16, 2021 at 10:03 AM
    twitchhero
    twitchhero ___YOU BOYS LIKE___ MEX-I-CO???
    North Carolina
    2017 Tacoma TRD Off-Road
    See Profile for a full list of Modifications: *Suspension* -Total Chaos Upper Control Arms -Total Chaos Lower Control Arms -Rock Rash performace welded spindle gussets -King EXT Coilovers with adjusters (front) -King Tundra EXT Shock with adjusters (rear) -Icon RXT leaf pack (Option 2) -Timbren active off-road bump stops (front) -Timbren active off-road bump stops with U bolt flip kit (rear) -DRT cab mount relocation -DRT Shackle hangers with DRT cross member -Dobsins front leaf greasable bolts -Polyurethane front body mounts *Performance* -AFE intake (noisemaker) -JLT oil catch can -OTT Tune -Stoptech stainless steel brake lines -Power Brake D-Line kit -Extended stainless steel rear brake lines -AGM Odyssey battery -Tacoma TRD Pro Exhaust *Interior* -Window Tint -Tacoma Door Sill Protectors -Clazzio (black leather seat covers) -Dashtop Single Mount -Sound deadening material -GATOR floor mats -Cup holder hero mats -Garmin mini front dash cam -JOYING Headunit -Tacoma Kicker tweeter upgrade -Kicker KS front and rear speakers -Rear USB -Meso Customs interior lights *Exterior* -Tacoma tailgate inserts -Mobtown offroad "No drill" Bolt-on rock sliders. -All-Pro Hi-Lift bed rail mount /w Hi-Lift -Rear Diff breather relocated -Alpha REX TRD Pro style headlights -Baja Design squadron sport (Amber fog lights) -Total Chaos Fabrication bed stiffeners -Window Deflectors (AVS) -TRD Pro Grille -Summit DAKAR (BRONZE) -Toyo Open Country R/T Trail (35x12.50 R17) -Sequential turn signals -Softtopper (black) -Toyota Bed Mat -Vinyl wrapped tail gate (black) -C4 high clearance fender liners -C4 High clearance Rock Runner rear bumper w/ Baja Designs S1
    The baja light kits are so much brighter than the stock, you wont have to worry about angling them.
  3. Dec 16, 2021 at 10:09 AM
    K9TXS
    Clarksville, TN
    That's good. Thanks for the information.
  4. Dec 16, 2021 at 10:18 AM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    I just installed Diode Dynamics SS3 Pro SAE Fogs yesterday. First bonus, I was amazed at how fast the change was accomplished! First one was <10 minutes as I fumbled with locating all the OEM outer trim ring tabs. The second one was done in under 5 minutes.
    With these, no need to worry about angling adjustment. They're 80* and they push a hella-load of light off the edges. Intensity is incredible, too. You barely notice the headlights on low beam and we drove around last night on country roads and city and not one oncoming driver signalled their displeasure. These are simply badd-ass. Flush mount reverse lights are next!
    EDIT: These are set up with DD's "B-Kit" so they just slip into the OEM fog mounting bracket and the OEM adjustment crap just stays attached to the OEM fogs and out it goes. There is an adjuster screw on the DD's, though if needed.
    Tacomaryan18 and K9TXS[OP] like this.
  5. Dec 16, 2021 at 10:29 AM
    K9TXS
    Clarksville, TN
    Thanks
  6. Dec 16, 2021 at 10:29 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Do you have any desire to be street legal? If so, we offer the Diode Dynamics SS3 family of lights here at Hotshot Offroad (as well as the Baja lights). @GrizzledBastard alluded to them, but for a street-legal option there is currently nothing better out there that is legal (when properly aimed). If you don't care about legality, won't be running them in poor visibility conditions, etc then a case can certainly be made for the Baja Designs. The issue with the Baja Designs is that they have a ton of uplight so when conditions break down (snow, fog, etc where fog lights are intended for) they won't help as much as you would hope.
    GrizzledBastard likes this.
