fog light question
Discussion in 'Lighting' started by 09toyotacoma, Feb 15, 2010.
  1. Feb 15, 2010 at 8:13 PM
    09toyotacoma
    09toyotacoma [OP] Active Member
    NY
    09 4cyl 5spd 4x4 access cab
    If my tacoma didnt come with fog lights, are there still wires for them tucked away some where or does toyota use a different wiring harness?
    I also bought 2 kc daylighters that are 130 watts each for my bull bar but they are to big, they are to tall to fit between the bars. =(
  2. Jun 8, 2010 at 5:26 PM
    blackcamry
    blackcamry New Member
    Missouri
    06 Tacoma
    I have a 2006 Tacoma and it didn't come with fog lights and from what I have found out is that the 4 cylinder engines don't have the wiring harness under the hood for fog lights to plug into, only 6 cylingers engines come with the harness already there. Anyway I have put the fog lights in and bought a O.E.M. switch and put it in the dash. Here is the part I don't understand and that is the wiring harness is in the dash to plug into the switch. I have it installed and when you turn the switch on the light comes on in the switch. So the four cylinder engine doesn't have the harness under the hood but does have it in the dash. I'm still trying to figure what and how to wire it from the switch to the fog lights.
