Fog light questions 2014 Tacoma regular cab.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by siskat51, Jun 21, 2015.
  1. Jun 21, 2015 at 8:43 PM
    siskat51
    siskat51 [OP] Member
    Trying to set up some aftermarket fog lights on my 2014 taco. How do I find out how many amps my fog lights Will be using. Also I wanted them to shut on and off with the ignition so I currently have them on a " add a circuit" tapped into the headlights so 2 10 amp fueses. Will this cause the lights to draw to much power? It didn't blow a fuse but I'm want to be sure it won't cause a problem later. Thanks in advance.
  2. Jun 22, 2015 at 6:56 AM
    adamr94
    adamr94 Well-Known Member
    Adam
    NC
    06 Regular Cab 4x4
    If I recall, I put a 7.5 amp fuse in for them
  3. Jun 22, 2015 at 11:12 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    An H11 bulb (common fog light bulb) draws about 4.25a at 12VDC. Two would be 8.5a. You generally want to fuse at 125% of the maximum amp draw so that would put it at a 9.5a fuse, so 10a. I would probably just use a 15a fuse (next size up) as that wouldn't cause any issues.
    The lights will draw what they draw regardless of the fuse size you install. If the fuse is too small for the amperage, it will fail; if it is too large it may not fail when it should.
