Fog Light Relay 2009
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jrdbrn, May 9, 2011.
  1. May 9, 2011 at 4:09 PM
    jrdbrn
    jrdbrn [OP] Borne Fishing
    Jared
    Louisiana
    '16 Inferno Tacoma TSS
    I bought some fogs with the relay and switch from a member here and the relay has 5 pins. My truck only is capable of 4 pins. The middle of the two pins has 2 small holes instead of the long hole. The truck I bought it from was a 2010 and I have a 2009. It should have been the same relay, correct?
    Anyone have a part number for a 2009 Fog light relay?
    Thanks
  2. May 9, 2011 at 4:14 PM
    jrdbrn
    Jared
    Louisiana
    The relay I was sent is 90084-98032 which is also the fuel pump. Was I just sent the wrong one?
  3. May 9, 2011 at 5:25 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    The fog lamp relay for the 2009 and 2010 4.0 automatic Tacoma is the 4 pin 90080-87026, not the 5 pin 90084-98032.
    In a 2009 4.0 automatic, the Towing Tail and Batt Chg relays are also 90080-87026, so you could use one of those temporarily to test your fog light installation. Those are both used only for the trailer socket, so if you aren't towing, you don't need them.
  4. May 9, 2011 at 7:10 PM
    jrdbrn
    Jared
    Louisiana
    Yea, he sent the wrong one. He will send the right one tomorrow.
    Thanks
