Fog Light removal(HELP)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by milesc, Jun 20, 2022.
  1. Jun 20, 2022 at 6:20 AM
    milesc
    milesc [OP] New Member
    Miles
    2021 Toyota Tacoma TRD Off Road 4x4
    So I changed all my other lights to led. I am having so much trouble removing the old fog lights? They will not come out? Somebody help!!!!!
  2. Jun 20, 2022 at 7:53 AM
    Roll_Terps
    Roll_Terps Well-Known Member
    Maryland
    2017 SR DCSB White
    There is a screw or two that holding it in from the backside. If you have long enough arms, reach down from the top behind the headlights, find the screw head by feel, and use a stubby screwdriver to unscrew it. Then the fog light housings just pull forward out the front of the bumper. Hope that helps.
  3. Jun 20, 2022 at 7:57 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Turn the wheel all the way right or left. Partially remove fender liner and stick your arm in there.
  4. Jun 20, 2022 at 8:13 AM
    milesc
    Miles
    So I have to remove the screw to remove the bulb? Just want to be clear before I attempt again.
  5. Jun 20, 2022 at 8:18 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Should be two screws on the same side. The other side just sits in some tabs. Once the two screws are out, you should be able to rock the fog light out.
    Otterstuff likes this.
  6. Jun 20, 2022 at 8:27 AM
    Diego432110
    Diego432110 Well-Known Member
    2022 Tacoma TRD-offroad
