Fog Light Replacement "How To..."
Discussion in '2nd Gen. Tacomas (2005-2015)' started by giv, May 9, 2009.
  1. May 9, 2009 at 3:08 PM
    giv
    giv [OP] New Member
    Tacoma 4x4 SR5
    Needing to find out how to remove fog light from the bumper. I can't figure out what's holding it in there. I know... I'm a newbie to these newer models!
  2. May 9, 2009 at 3:32 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Are you replacing the bulb or the whole assembly?
    Added:
    The bulb is simple, unplug the connector then twist the bulb from the back and pull out.
    To remove the entire thing, unplug the connector. Then there's a tab on the inside of the fog light bumper (I think it's on the outer edge) that you need to press to release the fog light assembly. You might need some pressure from the back to pop it out. Hope that helps.
  3. May 9, 2009 at 3:37 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    It just has 2 ears on each side that pop into holes in the bumper for the light. there is also a clip on the adj srew coming straight off the back of the housing that pops into hole in bumper. Basically you have to grasp it slightly twisting to work the ears out & push from behind the light to release the adj knob. Work from under bumper to see where things are. you'll see what I mean. Then wire unplugs.
  4. May 9, 2009 at 3:38 PM
    bigmooze
    Richard
    Belle River, ON
    Much better description, thanks.
  5. May 9, 2009 at 3:55 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    The clip for the adj screw will probably stay in the bumper when light comes out. it has 2 knubs to relase it from the bumper. Take it out & put on the adj screw before putting light back in. Makes it much easier to get them back in.
