Fog Light Retrofit
Discussion in 'Lighting' started by Pugga, Nov 14, 2011.
  1. Mar 7, 2012 at 8:02 AM
    #181
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Water will get in through the wires. Are both wires are in a tube or something?
  2. Mar 7, 2012 at 8:08 AM
    #182
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    There's a rubber boot where the wires go into the projector. I coated the crap out of the whole damn thing with silicone. Literally, I gave everything a silicone bath except the lens, even the wires and there they plug in. If you saw the housing, you'd laugh because it's just a black silicone ball. I'm honestly at a loss trying to figure out how water is getting in, that housing should be sealed up tighter than a termite's butthole.
  3. Mar 7, 2012 at 11:58 AM
    #183
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Sorry to here of your troubles once again. Luckily, mine have not leaked or condensated....yet, but there is always that chance. When I put mine together I JB welded the entire housing...it's almost bullet proof. and when I siliconed the bulb gromet, I put some (very little) on the inside of it. Tried to seal it from both sides.
  4. Mar 7, 2012 at 12:04 PM
    #184
    Pugga
    Massachusetts
    I did the same thing! JB welded it solid, silicone before the bulb went in, and also on top of where the bulb/projector meet, siliconed the crap out of the area that already had JB weld and then smeared the silicone all across the back side of the housing. I'm beyond confused at this point. I think I'm going to drill a hole, glue some of that goretex stuff over the hole and call it a day :cool:
  5. Mar 7, 2012 at 12:06 PM
    #185
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Sounds like a plan.
  6. Mar 29, 2012 at 10:23 AM
    #186
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
  7. Apr 30, 2012 at 3:33 PM
    #187
    GoDeacsWFU23
    GoDeacsWFU23 Well-Known Member
    Jonathan
    Clemmons, NC
    2013 Tacoma PreRunner TRD Sport
    I just got my Blazer fog kit in the mail today from their 20% off sale this past week. Hopefully I don't screw it up.....doesn't look as easy as my headlight retro fit was.
  8. Feb 26, 2013 at 3:46 PM
    #188
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    This may be my next project :spy:
  9. Feb 26, 2013 at 3:47 PM
    #189
    Pugga
    Massachusetts
    You might have trouble sourcing the Blazer projectors. Last I heard they were discontinued and that was a while ago. There might still be a few sets kicking around but I don't know how available they are.
  10. Feb 26, 2013 at 3:52 PM
    #190
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Matchboxes are what they're selling for fogs now. That's what I'm grabbing.
  11. Feb 26, 2013 at 3:57 PM
    #191
    Pugga
    Massachusetts
    Can't wait to see those! The only bad thing about the matchboxes is that you really have to have everything sealed up really, really well since they won't hold water out at all. Also, I'm not sure if there is enough depth in the fogs to hold them since they have to fit completely inside the housing whereas the Blazers protrude out the back quite a bit.
  12. Feb 26, 2013 at 3:58 PM
    #192
    ChamYota
    Cam
    Is the fog projector worth it, the projectors i have now completely drown out my fogs, i cant see it getting better. :eek:
  13. Feb 26, 2013 at 4:12 PM
    #193
    Pugga
    Massachusetts
    They're really nice, but honestly after retrofitting (strictly looking at it from a light output standpoint) I'm not sure I'd do it again. Looks-wise, I'd definitely do it, I run with just the fogs on a lot and they are bright! I can easily drive with just my fogs on. All that being said, the H1's will drown out my fogs. If it weren't for the fore-ground limiter on the H1's, you'd be hard pressed to even tell that the fogs were on. If you do this mod, I'd suggest doing the fog light anytime mod so you don't keep cycling them off and on frequently.
  14. Feb 26, 2013 at 4:17 PM
    #194
    benbacher
    Anchorage, AK
    Shouldn't be any different than my fxr's. I'll
    Just get some rubber sleeve on there for that.
  15. Feb 26, 2013 at 4:25 PM
    #195
    ChamYota
    Cam
    I see... well i may be getting some 5100's for free so i may go get some eibachs instead... :anonymous:
    Thanks for the honesty pugga :thumbsup:
  16. Jun 6, 2013 at 3:17 AM
    #196
    trailhoor
    trailhoor Well-Known Member
    Colorado
    08 BLK TRD
    King Adj Remote C/Os, Icon UCAs, King Adj Remote Rears, Alcan Leafs, Light Racing Jounce Shocks, Defined Engineering Shackles, Defined Engineering X-brace, Hakkapelittas (winter), Tunes, TRD S/C, APR X-1, URD 2.825 pulley, AFE Stage II, Doug Thorley LT, All Pro Rear Plate Bumper, Tom Woods CV drive shaft, FX-R HID headlights, diff lock, door chime, fogs anytime, bright reverse lights, map lights wired to door lights, defrost A/C, bed bike mounts
    Reviving an old thread. Anyone try Matchboxes? The biggedt issue with them is they don't appear to be fully sealed in the rear..ugh?
  17. Mar 29, 2014 at 8:23 PM
    #197
    ESWOOSH
    ESWOOSH Member
    Magnaflow Exhaust Custom AirIntake Custom MB Rims 1.25" Wheel Spacer Custom Headlights Hid Headlighting 2 12" JL Subs Custom Interior Lighting Custom Interior Shifter
    ayyyyy just saw this post. Gonna do this myself, Probably start another thread of job. but i was thinking to make the seem look better where the dremeled clear plastic meets the black plastic you could paint the the part that meets on the clear plastic too so you dont see the silicone. im also probably going to put a rubber graumet between the two when i do to give it a smooth factory look.
  18. Mar 30, 2014 at 6:28 AM
    #198
    Pugga
    Massachusetts
    The one that I cut with a hack saw actually came out a lot better than the one I attempted to use the Dremel on. The Dremel was melting the plastic so the slower speed hack saw gave a much cleaner look. I suppose I could have polished the back side of the plastic around the outer ring where the cut was. That would have eliminated the white from the cut. You should definitely make another thread if you're going to try another method. There aren't many addressing a fog light retrofit, especially since you have an interesting new approach. Good luck :thumbsup:
  19. Sep 11, 2015 at 3:45 PM
    #199
    Fedzen
    Fedzen New Member
    Whoa, don't cut there, it's almost impossible to get lens out without wrecking the whole thing, much easier to cut along indebted line 1/2" from lens edge all around by dremel, and then glue pieces back by G-flex epoxy. Inner part could be painted black, lens portion 1/2" stays same inside shine color ... cut off line should blend in ... I haven't finished it though, just ordered new lights, but looks promising :)
  20. Sep 11, 2015 at 3:51 PM
    #200
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    I bought aftermarket replacement 05-11 fogs and got lucky with Morimoto LED Type-S close outs from theretrofitsource. Mated them together with a PVC 3" to 2" reducer and PVC contact cement. I'll see if I can find pics and post them up.
    Here's the for sale thread that has all the info: https://www.tacomaworld.com/threads/05-11-morimoto-leds.385066/
    Not trying to thread jack just show there's alternatives out there!
