Fog Light Retrofit
Discussion in 'Lighting' started by Pugga, Nov 14, 2011.
  1. Sep 11, 2015 at 3:56 PM
    #201
    ambiguous25
    ambiguous25 Well-Known Member
    Daniel
    Joliet, IL
    2015 White Access Cab TRD Off-Road
    electrical: Raizin voltage stabilizer and grounding package accessories: WT mats & side window shields and bug shield and bump step, Tacoma bed mat TRD: rear license plate frame, 6-spd shift knob, valve stem caps
    I see a lot of rum in these pics, you need to diversify
    Pugga[OP] likes this.
  2. Sep 11, 2015 at 3:56 PM
    #202
    ambiguous25
    Daniel
    Joliet, IL
  3. Sep 11, 2015 at 3:58 PM
    #203
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I did cut there and it works out just fine :not sure: The lights went back together just fine, sealed up well and I ended up selling them to another member. Where I cut looks easier to get back together than where you cut if I'm honest. Mine was sealing the lens back against the housing. I had two flat surfaces to bond together. You have to match up your edges and make sure they stay perfectly set while the adhesive sets.
  4. Sep 11, 2015 at 3:58 PM
    #204
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    It's too bad when someone posts a pic like that they don't have a location in their profile. I don't blame you- I wouldn't want new friends showing up thirsty either!
  5. Sep 11, 2015 at 3:59 PM
    #205
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Could always mark the lens and housing before cutting so they line up when putting them back together.
  6. Sep 11, 2015 at 3:59 PM
    #206
    Pugga
    Massachusetts
    I have the rest of the bar tucked away safely :)
  7. Sep 11, 2015 at 4:00 PM
    #207
    Pugga
    Massachusetts
    I know you can align it rotation ally, but you then have to keep the edges perfectly aligned on top of one another so you don't have a big ugly seam.
  8. Sep 11, 2015 at 4:01 PM
    #208
    ambiguous25
    Daniel
    Joliet, IL
    we (the wife and I) have a big Halloween party every year, we're in Joliet IL, this year we have visitors coming from Indiana Wisconsin and Oklahoma
    back on topic, those lights look bad ass !
    JustinL likes this.
  9. Sep 11, 2015 at 4:30 PM
    #209
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Pretty sure you can throw the fog lights in the oven to separate them
  10. Sep 11, 2015 at 6:39 PM
    #210
    Pugga
    Massachusetts
    Negative ghost rider. At least not pre-2012, not sure about the new ones. 100% positive you can't separate the fog lights in the oven, they are not sealed like the headlights.
    ChadsPride likes this.
  11. Sep 13, 2015 at 7:21 AM
    #211
    MTopp
    05 SR5 4x4
    Have you tried? I asked a couple people who said they used the oven method. I'm gonna try soon with a junk fog light and see. I didn't think so either.
  12. Sep 13, 2015 at 6:26 PM
    #212
    Pugga
    Massachusetts
    No, there's no glue joint like the headlight, no separation point. The lens is attacked to the housing by heat welding of some sort. I cut the joint between the lens and the housing, it made a nice, clean separation, was fairly easy and the pieces mated together perfectly.
  13. Sep 14, 2015 at 9:38 AM
    #213
    MTopp
    05 SR5 4x4
    Hmm alright
  14. Jul 29, 2016 at 10:48 AM
    #214
    11TX_PRO
    11TX_PRO Member
    RYAN
    2011 TACOMA TXPRO
    You definitely can't bake them... A bandsaw also works if you happen to have one.
