Fog Light Retrofit
Discussion in 'Lighting' started by Pugga, Nov 14, 2011.
  1. Dec 6, 2011 at 4:49 AM
    #41
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    These should be a fog pattern, low and really wide. I've got PIAA driving lights mounted up higher, these will hopefully be good foul weather lights.
    The Captain was a carry over from my original post. I put up pictures of the TRS and everyone seemed more interested in the bottle of Captain in the back ground than the parts. IMO, the Captain is the most important part of the whole process. You gotta have a victory dance :D
    Everything is dried up, I just need a free night to get it mounted up and tear apart the other one! Unfortunately I leave for work around 6 AM and get home around 8 or 9 PM so weekends are about the only time I have that it's still light out :(
  2. Dec 6, 2011 at 7:29 AM
    #42
    superwhite10
    superwhite10 Well-Known Member
    Garner, NC
    Understandable, im in the same boat. Go to work early in the AM get off n its dark out or get off sit in traffic then its dark out :(
  3. Dec 6, 2011 at 7:31 AM
    #43
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    yesssssssssir! :)
  4. Dec 6, 2011 at 7:37 AM
    #44
    Pugga
    Massachusetts
    Did you do anything special with the ballasts? I'm just going to mount them as high as I can and in a place so they won't take direct contact from any road debris. I wasn't sure if I should seal them up or anything though, my gut says they're made for it and will be fine but if a little silicone will prolong their life, I'll gob them up :notsure:
  5. Dec 6, 2011 at 7:44 AM
    #45
    AsianAnts
    AnT
    nothing special at all.. i used the mounting hardware it came with and a self taping screw to screw into the side of the backing of the fog light (cone shaped)
  6. Dec 7, 2011 at 6:13 AM
    #46
    Yota Toy
    Yota Toy Taco Sauce
    FX retros, Blazer fog-light retro, JVC KW-NT30HD head unit, Pioneer 6X9's in front doors, Pioneer 6.5's in rear doors, two Pioneer 12" subs in sealed boxes, Sony X-Plod amp, Hidden Hitch trailer hitch, EGR window visors, two PIAA low-tone horns, Westin light bar with two 100-watt KC low profile driving lights.
    Looks great!
  7. Dec 7, 2011 at 6:36 AM
    #47
    Pugga
    Massachusetts
    Thanks! Hopefully the tear down of the second housing starts tonight so I can get them mounted and wired this weekend :goingcrazy:
    Plus I think if I make the kitchen my workshop too much longer, my girlfriend might take action... :eek:
  8. Dec 10, 2011 at 9:54 AM
    #48
    shweller
    shweller Well-Known Member
    Corona
    2010 Tacoma TRD Sport SB 4x4
    PoP 'N' Lock Satoshi Grill (Did it Myself) DSM UCA's (Desert Products) FXR 1.1 w/Gatling Gun Shrouds Phillips 85122 Method Racing Wheels HID Hella 500's behind Satoshi grill Fog Light Anytime Illuminated 4x4 Switch Ultragauge PIAA 510"s King Coilovers w/resi's Rear TSB Leaf Packs All Pro Sliders Bolt on sliders 255/75 R17 BF Goodrich Mudders Spidertrax wheel spacers Neoprene arm rests Weathertechs Wet Okoles w/TRD Allpro Ofrroad Apex bumper and IFS skid plate
    Your retro is coming out awesome, are you going to use the harness for TRS?I was going to do a plain OEM look retro but after seeing yours I am thinkingabout doing something crazier. Since I have a set of Morimotos on my headlightswith CCFLS, I was thinking of doing what you did except leaving it chrome andputting a CCFL ring on the inside of the outer edge of the reflector bowl.....
    http://www.hidplanet.com/forums/sho...aylight-8-angel-eyes-RETROFIT-on-My-11-Tundra
  9. Dec 10, 2011 at 2:01 PM
    #49
    Pugga
    Massachusetts
    Holy crap, that Tundra has LS460's and LS430's?!?! :eek:
    I was hoping to get mine finished up this weekend but had to attend a funeral so, needless to say, I've been a little preoccupied. I should be able to get them most of the way done tomorrow. I don't plan on using the wiring that came with the projectors because the ballasts will plug directly into the existing fog light wiring (no need for redundant power supplies and relays in my opinion). I can't wait for these to be finished, I'm getting anxious!
  10. Dec 10, 2011 at 9:05 PM
    #50
    superwhite10
    Garner, NC
    the lights on that tundra ^^^ are sick!!
  11. Dec 10, 2011 at 11:30 PM
    #51
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    :eek::eek::eek::eek::eek:
  12. Dec 11, 2011 at 12:05 PM
    #52
    Pugga
    Massachusetts
    First light installed, ballast mounted and wired. Second light is well underway :D
    I'll try to get night shots tonight. The came on pretty green looking so I'm hoping they'll yellow up once they get run in a bit. I did the return wire down mod and even in the day light, I have a nice, clean cut off and what will definitely be a very wide pattern. I think having the projectors sitting so far forward really gave me a nice wide beam pattern.
  13. Dec 11, 2011 at 2:43 PM
    #53
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    he is running the ls430 and mini H1's not ls460's.
    thats a nice quad set up if you have the room which most headlights need to be completely butchered to make them fit the ls430 is the widest beam you can get followed very closely by the ap1 s2k then the ls460.
    i plan on running a quad set up on my tacoma i should be one of the first or
  14. Dec 11, 2011 at 2:45 PM
    #54
    Pugga
    Massachusetts
    I can't wait to see a quad set up on a Tacoma!
  15. Dec 11, 2011 at 6:16 PM
    #55
    shweller
    Corona
    That tundra is sick! Makes me want to sell my Morimotos and do a LS430 retro..... I wonder if the stock wiring can handle the HID on the fogs? Looking to start my blazer retro in few days.
  16. Dec 11, 2011 at 6:45 PM
    #56
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i'm looking at running either ap1 s2k's another set of fx-r or i have sitting in my basement a brand new set of mini d2s and a brand new canbus harness lol.
    i don't know if i want to spend another 500 in parts alone just to add light on the road i really don't even need lol.
    i'm debating on wether or not i even want to wire them to be a true quad set-up or just use my existing arb switch and use them as fog lights with 3000k bulbs thats what i really want or run them as quads and just use a 3k bulb for the fogs.
    either way it's going to be pretty nice i want to put something in the arb's that has more performance than the d2s but, price wise it makes more sense lol.
  17. Dec 12, 2011 at 8:46 PM
    #57
    AsianAnts
    AnT
    looooooooooking great pugga wugga!!! make me want to chop mine up and get a shroud too :D
  18. Dec 13, 2011 at 5:00 AM
    #58
    Pugga
    Massachusetts
    The light output is freaking great! Even with only the passenger light done, it lights up from the driver's side of the truck and well onto the shoulder. The second one is coming out a little better and should be done shortly. I just have to silicone on the lens to the housing, plug in the wiring and I'll have a complete set :yay:
    Were yours green when you first fired them up? After being on for a few minutes they seem to yellow out a little bit but not much. I've heard about 'burning the bulbs in' but will that make them more yellow?
    Hey Ant...
  19. Dec 13, 2011 at 6:22 AM
    #59
    AsianAnts
    AnT
    HAHAHAH.....
    yea they are greenish when you first turn em on... then after a while it turns yellow.i havent noticed a 'more' yellow since i first used it...... and i've been leaving the fogs light on always....
  20. Dec 13, 2011 at 7:23 AM
    #60
    Pugga
    Massachusetts
    Hopefully they change colors with time. Right now they're like slimer green, like really green. After about 5 - 10 minutes, they start to turn a greenish yellow but still a lot of green in them. If they don't change to yellow soon I'll be in contact with the friendly staff over at TRS, I'm not trying to recreate the Ghostbusters car here... :cool:
