Fog Light Retrofit
Discussion in 'Lighting' started by Pugga, Nov 14, 2011.
  1. Feb 6, 2012 at 7:19 AM
    #161
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    They look awesome !
    I wish you were having better luck with the water getting in .
    I'd like to do this retro fit but sounds like there more of a pain in the ass then my retro headlights .
  2. Feb 6, 2012 at 7:28 AM
    #162
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I have a theory about the leaking fog light... That light was leaking before I did the retrofit (part of the reason I went ahead and did it) and I think it might have a hairline crack in the housing itself. I'm going to paint the back of the housing, reseal the whole thing up and hope for the best. There was only a tiny bit of water inside the projector itself this time and more water inside the fog light lens. I'm hoping that paint will make sort of a barrier that will seal up any minor cracks and prevent water from seeping in. If this doesn't work, well I suppose I'll cross that bridge when I come to it.
    The driver's side one sealed up perfectly and I've had 0 issues with it. Something is up with the passenger side, just can't put my finger on what it is. The light output is great though, even with the issues, I'd do this again in a heartbeat!
  3. Feb 6, 2012 at 7:38 AM
    #163
    johnnym
    john
    NH
    Might have to add this to my list :eek:
    I love the output on my retro headlights best lights on all the vehicles I've ever owned . Maybe I'll check yours out if you go to the next mass meet .
  4. Feb 6, 2012 at 7:54 AM
    #164
    Pugga
    Massachusetts
    I'll get to one of them! Once things slow down at work at with my house I'll make more meets. I'm hoping to get to the NH one people keep talking about :D
  5. Feb 29, 2012 at 9:21 AM
    #165
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    It appears trs dosnt have these... where did you get them?
  6. Feb 29, 2012 at 9:39 AM
    #166
    Pugga
    Massachusetts
    I got mine from TRS. You might want to call them or e-mail them. You're right though, I don't see them listed on their website anymore for some reason. Otherwise, you might find the projectors on Amazon or Ebay, then get the rest of the components through TRS so you're not stuck with a cheap HID kit.
  7. Feb 29, 2012 at 9:43 AM
    #167
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    I like those blazer ones with the tabs... quick bracket and stick them inside the allpro bumper
  8. Feb 29, 2012 at 9:48 AM
    #168
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
    I think Matt said they were discontinued?? I think I saw it on hidplanet. He said they would try to find something to replace them but could take a while.
  9. Feb 29, 2012 at 9:51 AM
    #169
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Bummer :( Thanks for the info
  10. Feb 29, 2012 at 9:51 AM
    #170
    Pugga
    Massachusetts
    I'd still call them, they might have a spare set kicking around to sell you. They do have a decent stock of parts on hand.
  11. Feb 29, 2012 at 9:54 AM
    #171
    tbturner47
    This is true, couldn't hurt to call.
  12. Mar 1, 2012 at 11:09 AM
    #172
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    They are getting a big shipment in sometime soon. This will be the last of the he said.
  13. Mar 1, 2012 at 11:10 AM
    #173
    Pugga
    Massachusetts
    :woot:
  14. Mar 1, 2012 at 11:15 AM
    #174
    Tuctaco
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    I'm getting ready to pull the trigger on my 2012. Anyone try this on a 2012?
  15. Mar 2, 2012 at 3:33 AM
    #175
    tbturner47
    Working on it now...
    The 2012 fogs don't give much room though
  16. Mar 2, 2012 at 4:44 AM
    #176
    Pugga
    Massachusetts
    Are you doing shrouds and all or just fitting the Blazer projector into the 2012 housing?
  17. Mar 3, 2012 at 5:16 AM
    #177
    tbturner47
    Started out trying to fit it in the housing, but the 2012's are angled and it makes it difficult. I should be done Monday or Tuesday, and ill post pics of how I did it:cool:
  18. Mar 6, 2012 at 3:09 PM
    #178
    Tuctaco
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Hey Travis,
    Have you done the retro on your headlights?
  19. Mar 7, 2012 at 4:46 AM
    #179
    Pugga
    Massachusetts
    Update, the passenger side has condensation in it once again... :annoyed:
    I need opinions. The driver's side light has been sealed up for months, not a drop of condensation in there. The passenger one has been torn down, cleaned up and resealed 3 times and it still won't stay sealed. If you saw it this last time, you'd laugh, I coated the entire housing with silicone, the only exception being the lens. Seriously, I used an entire tube of RTV silcone on the f-in thing! So, here's my next approach... I want to drill a small hole in the bottom of the housing to let it 'breathe'. I'm going with the mentality that water is going to get in, so I might as well plan for it and give it a place to get out. Thoughts?
  20. Mar 7, 2012 at 5:04 AM
    #180
    Pugga
    Massachusetts
    Oooh... that's a good idea! Thanks Brock! :thumbsup:
