Fog light Solution for 2012+ Tacomas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cfagan14, Jan 18, 2013.
  1. Feb 3, 2013 at 8:26 AM
    brian9682
    brian9682 Member
    Brian
    Tallahassee, Fl
    2013 PreRunner SR5 Double-Cab
    after purchase: factory fogs, tow package tailgate anti-theft clamps and washers Undercover Flex Polk Audio DB6501 components in front Polk Audio DB651 in rear
    This wiring harness is much more difficult than it needs to be and 2 relays, diode adapters, light switches with only 3 wires going to it. I am starting to have my doubts.
    It took me about a 1.5 hours to install an copycat Toyota (ebay) set on my daughter's Corolla. This Tacoma "Toyota" set has me on day #2 with no end in sight. The install was in 30 minutes. The electrical is another matter.
    It may be a call to the vendor on Monday and ride the motorcycle to work if I can't get it figured out today.
    Brian
  2. Feb 3, 2013 at 11:03 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I'll send it to you. Shoot me a PM
  3. Feb 3, 2013 at 11:41 AM
    itsakeeper
    itsakeeper Well-Known Member
    nova scotia
    2012 SR5
    I already have a volunteer who will do that for me and I thank you as well for your generous offer.
  4. Feb 3, 2013 at 12:18 PM
    brian9682
    brian9682 Member
    Brian
    Tallahassee, Fl
    Well, I disconnected everything and started over, checking voltages as I went. I did move the fused power supply from the green/white wire to an open fuse link on the fuse panel that operates with the ignition switch.
    The diode adapter seems to prevent reverse power draw. Without the diode adapter in place and my lights on, I had a live cigarette (accessory) power jacks. When I installed the adapter, it killed the power to the accessory jacks with only the lights on, I had to power the ignition on to get voltage to the jacks like when I bought the truck.
    Everything is now working and this project is behind me.
    Thanks to everybody that sent ideas.
    Brian
  5. Feb 4, 2013 at 8:18 PM
    TacoUGA
    TacoUGA Member
    Adam
    Tucker
    2012 V6 Prerunner
    Got my kit installed tonight in a little over two hours. The instructions were pretty straight forward, but the descriptions for wires to tap into were a little lacking, and the wiring diagrams did not match my truck. I finally figured out that there is only ONE white wire, and ONE red/black wire in the area, so I tapped them and everything worked great.
    Very clean looking install with the OEM lamps and switch. The kit is definitely a good deal.
  6. Feb 5, 2013 at 5:09 AM
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    Tacouga, did you tapped the wire to the low beam right?
  7. Feb 5, 2013 at 5:24 AM
    TacoUGA
    TacoUGA Member
    Adam
    Tucker
    2012 V6 Prerunner
    Yes, the lights work only when the low beams are on. I tapped the recommended wires in the kit's instructions.
  8. Mar 28, 2013 at 5:08 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  9. Mar 28, 2013 at 8:23 AM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    Yea the diode part threw me off for a second when I done mine. I looked and looked then seen it in wire and hoped for the best. Mine have been great only thing I don't like is the relay is loud when they are turned on and truck on? Not big deal I just think the click sounds cheap.
  10. Mar 28, 2013 at 9:02 AM
    Tex-Tac
    TEXAS
    When you say that the 'relay is loud' when turned on and a clicking sound is heard are you saying that it is a continuous 'clicking sound' or just a one time 'click sound' is heard when the switch is initially turned on?
    Everything grounded properly? Did you double check all connections?
  11. Mar 28, 2013 at 11:30 AM
    Baoser
    Baoser Well-Known Member
    George
    Pittsburg, CA
    2012 DCSB Offroad
    I have a 2012 White bumper + fogs (no harness/switch) for sale Local Sales preferred =)
  12. Mar 28, 2013 at 1:12 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Yea it clicks when you turn key on then when you turn lights on. Just once.
  13. Mar 28, 2013 at 3:31 PM
    FLAJIM
    FLAJIM Well-Known Member
    Jim
    Daytona Beach, Fl.
    2012 PreRunner SR5 2WD
    ARE tonneau cover, Electric Pop & Lock tail gate, 2 lighter plugs in bed, Reese hitch/ factory wiring, OEM Bed Extender and fog lights.
    Been off this site for awhile, work and family biz, However I am so happy to find this kit. Just ordered it and hope to have it installed next week.
    Be Safe JIM
  14. Mar 28, 2013 at 5:06 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    It is a very nice kit. Make sure to look at online instructions(color) plus that link a above that fixes the original instructions.(manly the diode part) but over all I could not be happier and its the best priced "OEM" kit I found.
  15. Mar 28, 2013 at 8:33 PM
    #35
    FLAJIM
    Jim
    Daytona Beach, Fl.
    Tks for the info, Be Safe JIM
  16. Apr 7, 2013 at 12:31 PM
    #36
    FLAJIM
    Jim
    Daytona Beach, Fl.
    OK bought and installed this kit but I would really like to have it work with just the parking lights on. I see the MOD for the factory install lights but is there a MOD for this kit ???
    Thanks in advance JIM
  17. Apr 8, 2013 at 6:52 AM
    #37
    FLAJIM
    Jim
    Daytona Beach, Fl.
    Anybody..... any ideas ????? Be Safe JIM
  18. Apr 9, 2013 at 9:43 AM
    #38
    FLAJIM
    Jim
    Daytona Beach, Fl.
    Oh well, I guess there's no mod for this kit...... really wanted to set them up with the parking lights........
  19. Sep 26, 2013 at 5:43 PM
    #39
    Flyingtiger
    Flyingtiger Member
    A very old bump, but I need help. I ordered this kit and tried to install this afternoon. Got everything set up right per the new updated instructions that came with the kit. Result: the switch lights up, but the lights will not come on?
    Helllllllllllpppppp
  20. Sep 26, 2013 at 5:51 PM
    #40
    Flyingtiger
    Flyingtiger Member
    disregard, I found link to help. hope it works
