Fog light switch does not light up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hansolo2005, Dec 24, 2009.
  1. Dec 24, 2009 at 7:45 AM
    hansolo2005
    hansolo2005 [OP] Active Member
    I have an 05 TRD OR 4WD. I notice the other day my fog light switch has a bulb in it but it doesn't light up. I know on the 09 models the fog light switch lights up. Is light dead or is this normal for the 05's ?
  2. Dec 24, 2009 at 8:01 AM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    mine doesnt light up?
  3. Dec 24, 2009 at 8:02 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    The LED bulb is dead. I'm after replacing several in the RR Locker and fog light switch. They don't last long and the only place I've located them is the dealer.
  4. Dec 24, 2009 at 8:29 AM
    Chickenmunga
    Chickenmunga Nuggety
    Hillsboro, Oregon
    08 TRD Offroad DC 4x4 (read the build)
    I thought I heard that they didn't light up the fog switch until '09?
  5. Dec 24, 2009 at 8:33 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Mine doesn't light up.
  6. Dec 24, 2009 at 8:33 AM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    They light up in all years. Take the bulb out and go to the dealer. It's like 2 dollars for each one.
  7. Dec 24, 2009 at 8:53 AM
    Chickenmunga
    Hillsboro, Oregon
    Dammit, that's going to be hard to get to.
  8. Dec 24, 2009 at 10:09 AM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    Red Prerunner AC
    Mine has always lit up. Same bulb since 2005.
  9. Dec 24, 2009 at 10:25 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    So your saying there's allready a bulb? My 07 has never lite up from day one.
  10. Dec 24, 2009 at 10:28 AM
    ExpoSpy
    ExpoSpy Well-Known Member
    Brian
    S.D.
    08 DCLB 4X4
    Mine never lighted up either...:confused::confused: and I'm an '08
  11. Dec 24, 2009 at 10:34 AM
    Chickenmunga
    Hillsboro, Oregon
    Is there an easy way to get to it that I don't know about? Right now I'm mentally preparing to dump the whole dash.
  12. Dec 24, 2009 at 10:52 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    The switch lights up with parking lights but does not light up any differently when fogs are actually on.
  13. Dec 24, 2009 at 10:55 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have an 06' and I dont think mine has ever lit up. Great now I'm going to have to check when I get home!!!:eek:
  14. Dec 24, 2009 at 11:16 AM
    mr2crazed
    mr2crazed Well-Known Member
    Morro Bay, CA.
    06 DC PreRunner SR5
    I have an '06 and didn't light initially until I tapped it enough times for it to come on. It's been about 5 months and has been on ever since. I have a friend with an '07 and his is also lit.
  15. Dec 24, 2009 at 1:35 PM
    OffroadToy
    4X4 Offroad
    Well, after initially posting that my fog-light switch has never lite up I went out to the truck and after turning on the parking/headlights it does. I guess I was thinking more about the fact that there's no light on the dash to let you know when the fog-lights are on or off.
  16. Dec 24, 2009 at 1:51 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    It was suggested in another thread that you may be able to pull the little cubby insert (coin drawer) out and pop the switch out from the backside.
    Another member suggested using a screwdriver. See the linked thread above for more details.
    Here is a diagram which shows the cubby insert.
  17. Dec 24, 2009 at 2:14 PM
    automoto
    automoto Well-Known Member
    jersey shore
    07 SR5 4X4 AC
    2007 sr5, my switch lights up :taco:
  18. Dec 24, 2009 at 5:22 PM
    Fortech
    CANADA
    Switch can't be pryed out with a screwdriver or pushed out from the rear by removing the coin tray (not unless you have 8 yr old girl hands).
    From what I remember you have to remove the screws on the lower portion of the dash and fold it downward towards the floor. This will give you access to the screws for the top (black) portion of the dash. Remove enough screws until you can gain access to the back of the switch, unplug the harness, and remove.
  19. Dec 24, 2009 at 6:50 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I can repeat this post until everyone understands...............and we are talking about the factory switch. Unless the bulb is burnt out it works as posted.
  20. Dec 24, 2009 at 6:54 PM
    krans
    krans Well-Known Member
    Kenny
    Huntington beach/ West min duh
    09 Sport mall crawler
    Icon extended travel with resi front and rear,Camburg UCA, All pro standard leaf pack, Fogs anytime, General grabbers AT2,Custom stainless steel brake lines,bed box, Bestop soft top,50' light bar, amber rigid pods,CBI ditch mounts with LED pods,TRD intake,Anti dark hoodlights/rock light/LED whip,FX-R retros and Gibson catback..more mods to come
    danngg.... now i have to check...
