Fog Light Switch Illuminates Sometimes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by parfleet, Jan 11, 2014.
  1. Jan 11, 2014 at 9:33 AM
    parfleet
    parfleet [OP] Well-Known Member
    Rex
    Pensacola, FL.
    05 PreRunner, SR5 Package, 4.0 Engin
    Front Bush Guard with 100 Watt Driving Lights, Color Match Tonel Cover. Cold Air Intake By True Flow,added an additional 26 HP.
    The fog light switch illuminates sometimes when I engage the flog lights. I was able to reach the back of the switch and push on the plug thinking perhaps it was just a loose connection. At this point I am ready to either replace the bulb inside the switch (and I have no idea of how to do that but I know it has one) or to replace the switch with a new one. My question is this: how do I remove the switch? I tried a small plastic pry tool and also I tried a small screwdriver. Neither go the job done. I suppose I could just destroy the switch and pull it out but I know there must be a smart way to remove the switch. Any idea's other than destroying the switch to get it out? My vehicle is a Tacoma PreRunner, 4.0, Crewcab. It is the first year of the 2nd Generation Tacoma's.
  2. Jan 11, 2014 at 5:55 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    pretty sure the switch itself doesnt illuminate when you push the switch... but rather illuminates when you turn headlights on with the rest of the dash.
  3. Jan 11, 2014 at 6:05 PM
    Dr 10Jeeps
    Dr 10Jeeps Well-Known Member
    Larry
    Ontario, Canada
    '13 Tacoma 4X4 (TRD, Trail Pkg)
    My switch doesn't illuminate.
  4. Jan 11, 2014 at 6:10 PM
    kn61408
    kn61408 Retired old fart
    western washington
    09 PreRunner DCLB sport pyrite mica
    12v always on power point mod, tailgate anti-theft, Addl bed tiedowns, flyzeye dash lights, map lites with dome lite mod, bed stiffeners, air bags, brake controller, always on fog lights,
    The switch lights when the lights are turned on. If your bulb is intermittent, you may need to clean the contacts on the bulb and to do that you need to take it out. Start by prying up the sill plate. Remove the floor left foot rest and unscrew the lower left kick plate fastener. remove the kick plate. Remove lower dash coin holder. Remove 2 (or 3?) lower dash 10mm bolts and remove lower dash. Pull forward on dash housing the switches, disconnecting the plugs. The switch is held in with clips top and bottom. Alternatively, once the lower dash is removed, poke a finger underneath the switch to release the lower clip and push forward. Then the switch will disengage and pull forward enough to get to the lightbulb. Clean the contacts and replace. Not as hard as it sounds. Takes about 10 minutes. Search the forum for pics.
  5. Jan 11, 2014 at 6:15 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
  6. Jan 11, 2014 at 6:41 PM
    RedlineTRD
    RedlineTRD Well-Known Member
    Kyle
    Peyton, Colorado
    2017 Tacoma TRD OR DCSB MT
    Working on it.
    nailed it....x2
  7. Jan 13, 2014 at 11:00 PM
    evan164
    evan164 Well-Known Member
    Evan
    Louisiana
    05 Prerunner SR5
    Added a trailer hitch and the 4 pin connector
    Mine use to do that. Actually did it until about two years ago. Ever since then it stays illuminated whether the fog lights are on or not. I don't know what changed.
  8. Jan 15, 2014 at 6:18 AM
    Dr 10Jeeps
    Larry
    Ontario, Canada
    My above comment was misleading (actually, it was just plain wrong). My fog light switch does illuminate when the headlights are turned on. What I was trying to say is that there is no indication on the dash whether the fogs are on or not. Every other 4X4 I've had let me know by some sort of idiot light that the fogs were on. Not a big deal, but there probably should be an indicator similar to the idiot light that tells you your headlights are on.
