fog light switch
Discussion in 'Lighting' started by diezel485, Mar 3, 2011.
  1. Mar 3, 2011 at 11:02 AM
    diezel485
    diezel485 [OP] Well-Known Member
    DJ
    Lafayette, LA
    08 Double Cab TSS
    front level, rear AAL from Toytec, Westin 4" chrome bull bar, 10% tint all the way around, 6" KC foglights behind the grill, billet grill
    i have a set of kc off-road fog lights that i have run to the kc switch but i would rather the look of the factory switch. would the factory switch have enough amps to run the fog lights or would i burn fuses all the time?
  2. Mar 3, 2011 at 12:29 PM
    Badwin45
    Badwin45 Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    The factory switch probably isn't capable of handling more amps than the KC switch. Are you running your lights through a relay?
  3. Mar 3, 2011 at 12:33 PM
    diezel485
    DJ
    Lafayette, LA
    08 Double Cab TSS
    yes. i actually have a relay box as well as a fuse on another wire.
    i used the factory wiring kit that comes with the KC lights.
  4. Mar 3, 2011 at 12:54 PM
    diezel485
    DJ
    Lafayette, LA
    08 Double Cab TSS
    i believe its the harness with the 40amp switch
  5. Mar 3, 2011 at 1:19 PM
    diezel485
    DJ
    Lafayette, LA
    08 Double Cab TSS
    i would have to look at the actual relay, but yea, that's what my setup looks like.
    so your saying, if that is the case, then i should be able to get a factory oem switch to run to those lights?
  6. Mar 3, 2011 at 1:49 PM
    diezel485
    DJ
    Lafayette, LA
    08 Double Cab TSS
    thanks for the help man!!!
