Fog light Switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by alopez910, Mar 10, 2015.
  1. Mar 10, 2015 at 5:26 PM
    alopez910
    alopez910 [OP] Well-Known Member
    Tony
    South Texas
    2009 DCSB TRD Sport Prerunner
  2. Mar 10, 2015 at 6:00 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    There is likely the same outputs from the OEM switch, although maybe not in the same order. The two green wires to the switch are dimmer wires. The rest should be easy to figure out with a multimeter or 12v power light/tester.
  3. Mar 10, 2015 at 8:25 PM
    cobracomander
    cobracomander Well-Known Member
    I just did this on my FJ. I spliced the two middle wires together with the fog relay. Works like a charm.
  4. Mar 10, 2015 at 10:02 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    the above is not going to work. The fog light switch switches the ground side of the relay. so there is no switched power going on at the switch.
    There is a tutorial somewhere for this, as the switch itself is provisioned for an indicator light.
  5. Mar 10, 2015 at 10:10 PM
    cobracomander
    Hmmm, it worked for me.
  6. Mar 16, 2015 at 5:12 PM
    alopez910
    Tony
    South Texas
    Thanks I was able to get it working.
  7. Mar 16, 2015 at 6:00 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Install write up and pics to show what you did?
