Fog light wiring harness number
Discussion in '2nd Gen. Tacomas (2005-2015)' started by seabag, Oct 31, 2020.
  1. Nov 10, 2020 at 6:19 PM
    seabag
    seabag [OP] Well-Known Member
    Ben
    Maine
    2020 Black AC MT V6
    Fisher HS plow.
    Pretty interesting. Looks like the OEM harness had the power taps and relay all up in the dash area with the power taps on that fuze panel. My inclination and what I read of later installations have the light power tap down in the engine compartment along with the relay mounted down there and the only power tapping needed in the dash the light for the switch, which would be the way I'd be inclined to do it.
  2. Nov 10, 2020 at 8:20 PM
    caribe makaira
    Caribbean, Puerto Rico
    It's not really OEM, it's an add on set. If it where a proper one it would have Toyota connectors, not 3m T-taps.
  3. Jan 29, 2022 at 8:17 PM
    woodgeek
    woodgeek Member
    Dave
    2006 2.7 4wd
    Can you get the factory harness? I have a 2006 2.7l Tacoma 4x4 — no harness or relay, it’s the base 4x4.
    I want to install KC lights using the factory harness, switch and relays.
