Fog Light Wiring Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by decaye515, Oct 23, 2023.
  1. Oct 23, 2023 at 9:38 AM
    decaye515
    decaye515 [OP] New Member
    2012 Tacoma SR5
    I recently purchased a 2012 Tacoma 4x4 double cab base model and I'm trying to learn more about working on it myself using these forums, for the most part I haven't really had any major issues. Recently the passenger side foglight went out, so I purchased new bulbs and installed them without any issue but the passenger side foglight still wasn't working. My next thought was that there might a wiring issue, so without really thinking too much about it I purchased a cheap foglight kit from Amazon that included a switch, as I thought would be nice to be able to control when the foglights were on or off. However when I started looking over the foglight cables I realized that they were wired to turn on with the headlights and not separately wired. I haven't really been able to find any information on how these cables are normally wired online, in fact, most of the info I have found suggests the foglights are usually wired independently from the headlights. If anyone has any info on how these might be wired, how I can fix my foglight, or any related threads I'd really appreciate it. Also happy to upload additional info/photos if that may help.
    Thanks!
  2. Oct 23, 2023 at 10:33 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Have you tested for power with a test light, and usually the plug goes bad …..keep it simple when testing
  3. Oct 23, 2023 at 10:43 AM
    caribe makaira
    Caribbean, Puerto Rico
    The shared circuit of the headlights (low beam) is sent to a very small buss bar inside the engine bay fuse/relay box.
    This shared connection provides power to the fog lamp relay coil side (+) the negative side of the relay coil is controlled by the cabin fog lamp switch. It completes the circuit when pressed.
    When the High beams are selected, the fog relay coil looses fused power, shutting off the Fogs.
    P.S.
    VERY Easy to duplicate "externally".
  4. Oct 23, 2023 at 10:52 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Definitely keep it simple!
    And check that the new buib is good first of all.
    Going down the path of a new fog light kit sounds absolutely NUTS, @decaye515, to be honest. Probably 20X as much work as figuring out what you've got, and then a solution that isn't as good.
