Fog light wiring?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drewsky, Nov 12, 2011.
  1. Nov 12, 2011 at 4:55 AM
    drewsky
    drewsky [OP] Active Member
    Drew
    Kelowna BC
    08 DOUBLE CAB 4X4
    Howdy! I'm about to install an aftermarket set of fogs (switch, harness, relay included). Looks as if my truck has the plugs already in place from factory for fogs? My dash has 2 banks of blank switches,(SR5 model) but it appears there are wired plugs behind a few of them? Any idea if one could be for the factory fogs??? Which one???
    Cheers.
  2. Nov 12, 2011 at 5:13 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Top left one bud
  3. Nov 12, 2011 at 5:16 AM
    drewsky
    Drew
    Kelowna BC
    08 DOUBLE CAB 4X4
    Sweet! I assume a Toy factory switch should do the job then!
    Thanx.
  4. Nov 12, 2011 at 5:53 AM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    If you are pre wired you should have a fuse installed already for the fog lights. I think it is in the box in the engine compartment. If so, all you will need is the fog lights, switch, and fog relay. This is what I did, and the blank that is top and left next to the steering wheel is where the factory switch should be as preziously stated.
  5. Nov 12, 2011 at 10:16 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    Not tot hijack here but mine only has a prewired plug on the top right closest tithe steering column. What is that plug for? It has 5 wires coming out of it. I too am planning to install fog lights.
  6. Nov 12, 2011 at 10:29 AM
    Blackshirts
    TX
    Stuff
    That I believe top right is for the bed outlet.
  7. Nov 12, 2011 at 5:25 PM
    charles08tacoma
    Santa Cruz, CA
    Cool, thank you. I thought it might be but wasn't positive.
