Fog light wiring??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reaper22, Oct 30, 2009.
  1. Oct 30, 2009 at 1:37 PM
    Reaper22
    Reaper22 [OP] Well-Known Member
    Palmyra Missouri
    SR5 Tacoma
    Radient Red, Red Grille, Debadge'd, Blacken'd Headlights, DTRL's, Cruise Control, Fog Lights, 2 1\2" suspension lift, 285\75\16 Nitto Dune Grapplers, Pioneer Premier DEH-P510UB stereo, Pioneer 3 way fronts with factory tweeters & Kenwood tweeters, Kenwood truck boxes behide seats with 8" subs in each, Wet suit like tacoma seat covers
    Does anyone know where I can pick up wiring for fog lights? I found factory switches just need harness and relay..
    Thanks..
  2. Oct 30, 2009 at 1:38 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    Youre not already set up for it? were you a prerunner or a 5 lug base? what other equiptment do you have..? Cause you may have the wiring..
    EDIT: you say you're SR5.. you should have the wiring already. go digging.. you may have to take some tape off the original wiring harness to locate the actual plugs, but i'd be supprised if you werent already wired up.
  3. Oct 30, 2009 at 1:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Regular cabs dont come with the wireing.
    OP, they sell kits at most auto stores. Start there. :)
  4. Oct 30, 2009 at 1:45 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    seriously? You would think they would considering its the same truck from door handle to headlamp..
  5. Oct 30, 2009 at 1:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah....Only the Extra cabs, and 4 doors have it.
  6. Oct 30, 2009 at 1:49 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    Yeah, trust me on this one Chris is right (of course). I spent about 4 hours looking for and identifying all of the additional plugs and stuff on mine and a Base model 5 lugger does not have it.
  7. Oct 30, 2009 at 1:49 PM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    Thanks guy's, You would think that if the cruise wiring was there the fog should be there also, but I will look harder to see..
  8. Oct 30, 2009 at 1:52 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    agreed. Sucks. They're not that hard to wire in though, and you could use the stock switch and the stock lamps, and run some wires and you'd be set. I agree with Chris - check out Auto Zone and whatever, they'd have wiring kits complete with fused blocks and what not. probably your best bet.
  9. Oct 30, 2009 at 2:15 PM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    Hey man, what do you mean by 5 lugger, If it relates to wheels mine is 6 bolt...So would that make mine any different??
  10. Oct 30, 2009 at 2:17 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    ssingle cab non prerunner is a 5 lug, youre SR5 prerunner/4x4, so you're 6 lug.
  11. Oct 30, 2009 at 3:53 PM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    Isn't prerunner like an extended cab? I do have an sr5 reg cab, confused on prerunner
    terminology..
  12. Oct 30, 2009 at 3:56 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    prerunner means youve got fender flares, lifted suspension or 4x4 with lifted suspension. If youre nonprerunner, its basic stuff under those leafs (or over them in that case)
